How can i find out if my stem seals are knackered!?
Old Mar 3, 2004 | 05:14 PM
Default How can i find out if my stem seals are knackered!?
Hi, ive got a smoke problem on my car, i think the stem seals are the culprits! Any way of finding out for sure without lifting the head!?
Old Mar 3, 2004 | 05:37 PM
rs graham's Avatar
rs graham
From: In the pub cheering on Ricky hatton and Joe calzaghe
stem seals will make the car kick out blue smoke on start up!
Old Mar 3, 2004 | 05:49 PM
and it'l smoke more or less all the time? Specially when you give it some? Turbos new, am i right in thinking that if the intercooler pipes have oil in them, then that means stem seals? Any other checks like that?!
Old Mar 3, 2004 | 05:55 PM
rs graham's Avatar
rs graham
how many miles has the engine done? im thinking rings.......
Old Mar 3, 2004 | 05:58 PM
Re-built not long ago, how much would rings be to sort out, not including taking off, and putting head back on?
How about the oil in i/c pipes?
Old Mar 3, 2004 | 06:05 PM
rs graham's Avatar
rs graham
if you had a full re build not long ago it will have new rings anyway!
Old Mar 3, 2004 | 06:16 PM
It was rebuilt before i bought it probly about 20k on the engine max!
Old Mar 3, 2004 | 07:15 PM
Old Mar 3, 2004 | 10:28 PM
owens130's Avatar
owens130
you can do valve stem oil seals without takin the head off if you have the rite stuff
Old Mar 3, 2004 | 10:56 PM
elaborate please mate
Old Mar 3, 2004 | 11:05 PM
owens130's Avatar
owens130
you have to keep the valve in place by pressurised air from a compressor and remove the nessasary parts, not the best way of doing the job but by far the quickest
Old Mar 3, 2004 | 11:50 PM
up
Old Mar 4, 2004 | 08:36 AM
Toe Knee's Avatar
Toe Knee
U havnt said what car its on?!?!?! ERSTs etc are a peice of piss to do, if its a cossie it can still be done but is a bit more of a pain in the arse.
Old Mar 4, 2004 | 12:21 PM
yep a cos!
Old Mar 4, 2004 | 12:52 PM
It's Czech Mate's Avatar
It's Czech Mate
If it's stem seals then it'll only blow blue on startup and then dissapear when run for a bit. If it blows blue when you boot it then something more serious is fooked!
cheeRS
Old Mar 4, 2004 | 01:33 PM
It does dissapear after a boot, are doing the rings, and stem seals about the same kinda job? i.e labour once the heads off?
Old Mar 4, 2004 | 01:36 PM
And it is deffo blue smoke, if the stem seals have been like this for a while untreated, can they get worse? What else could it be?
Thanks alot for your help everyone
Old Mar 5, 2004 | 10:04 AM
CabrioTurbo's Avatar
CabrioTurbo
They will get worse after time... as they become more brittle and let more oil past them
Other possibilities are worn rings (as said above) you would tend to find that the car smokes (blue) throughout the rev range and especially when under heavy load.
Of course turbo is a poss but unlikely as you say the smoke goes away after a while. turbo would normally only smoke on over-run (ie after you back off the throttle) pouring blue smoke out the back
To change the rings is... erm well not easy! the sump will have to come off and dependant on wether the car is 4x4 or not then it can be time consuming.
You will then need to remove the pistons and re-ring them.
This in itself is not guaranteed to cure the problem as the bore itself may be worn and ovaled therefore letting oil past the piston anyway.
Best option it to change stem seals and check bore condition (obviously with head off!) if there is a big lip at the top of the bores then i would say oil is passing the rings this however should be unlikely as you say the car has been rebuilt recently"!
CheeRs
Phil
Old Mar 5, 2004 | 11:38 AM
swerv's Avatar
swerv
stem seals will smoke between gear changes as well , similar symptoms to a worn turbo.
you can change the seals without taking the head off , and the seals are only around £25 i would start by doing that as it saves you from taking the head off.
rings are about £100 and a lot of hassle to change.
are you sure the engine has only done around 20k , what kind of spec is it??
Old Mar 5, 2004 | 05:07 PM
Hi, thanks for the help everyone So the seals can be changed by just removing the cam cover? Is the set of seals £25, how many are needed? The cars a 2wd, im sure it hasnt covered more then 20k, its just a stage 3
Thankyou!
Old Mar 5, 2004 | 05:15 PM
The previous owner told me the car recently had an exhaust valve or something replaced, and the head was sent off to the engineers for this to be done, they didnt replace the stem seals when this was carried out! I would have thought you would have had to?!
Old Mar 5, 2004 | 05:35 PM
rs graham's Avatar
rs graham
do the stem seals first you will need 16 and the cams need to come out!
Old Mar 5, 2004 | 05:55 PM
Just the cams? so all ill need is a cam cover gasket?
Old Mar 5, 2004 | 06:06 PM
Old Mar 6, 2004 | 09:47 AM
swerv's Avatar
swerv
you need the tool to this as well mate , sorry forgot to mention it!!
Old Mar 6, 2004 | 01:19 PM
Ok thanks, what about the above questions?
Old Mar 6, 2004 | 08:44 PM
up
Old Mar 6, 2004 | 09:43 PM
swerv's Avatar
swerv
as for gaskets only the rocker set yes.
if you are going to do it yourself , please make sure that the cambelt tensioner is good when you put it back togehter, if its old replace it!!
give A1 rally a call for the stem seals 01767 691617 they should have them in stock
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
IainRS1700T
Sep 25, 2015 06:44 AM
krypton
Sep 23, 2015 07:29 PM
