s2 wont find any radio stations, changed everything Help!!!!1
Old Sep 4, 2009 | 11:09 AM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default s2 wont find any radio stations, changed everything Help!!!!1
as above i got alpine headunit, the radio did have stations programmed into it but took of the road for the winter, now it wont find fuck all, i changed th aerial cable from amplifier to headunit, and changed the amplifier it self. still no joy.
The rear window demister dont seem to work great at all, but it use to work well.
Think the rear window could be at fault? fuse maybe?
Thanks
Old Sep 4, 2009 | 11:53 AM
jamieRST's Avatar
jamieRST
my rear window demister was playing up it was the tiny wire running out of the top of the window,it was loose,taped it down and it works now
Old Sep 4, 2009 | 12:36 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
i cant see any wires loose on mine, think it could be the fuse?
Old Sep 4, 2009 | 03:15 PM
jamieRST's Avatar
jamieRST
worth a check i guess
Old Sep 4, 2009 | 09:12 PM
Rob_DOHC's Avatar
Rob_DOHC
There is a wire between the boot and body in a rubber boot, aerial and demister. These wires can go intermittent before it breaks. I would check there, this is where mine is failing.
Rob,
Old Sep 4, 2009 | 10:28 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
them wires seem ok, how shall i check them?
Old Sep 4, 2009 | 10:35 PM
Rob_DOHC's Avatar
Rob_DOHC
Get a multimeter and do a continuity test, you can probably pinpoint a broken wire location like that, have you pulled back the rubber boot and had a good look?
Rob,
Old Sep 5, 2009 | 05:36 AM
Antti O's Avatar
Antti O
I have exactly same problem and coaxial is working ok from headunit, also amplifier gets voltage normally. I also did replace the amplifier in the boot but radio wont work.
Rear demister works normally.
Old Sep 5, 2009 | 11:33 PM
marky_g's Avatar
marky_g
Fleet Manager
id run a new internal mount aerial the rear screen thing is crap, its 20 year old technology!
i had a bee sting on my last escort worked grate,
im gonna go internal glass mount
Old Sep 6, 2009 | 09:16 AM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
right and how do you do this?, can you send me a direct link for the bee sting?
Old Sep 6, 2009 | 02:23 PM
Antti O's Avatar
Antti O
I now have aftermarket internal glass mount shit antenna and it is piece of shit.
I prefer that original which is integrated in rear glass, i believe it works great when i figure out whats wrong with it.
Old Sep 10, 2009 | 04:53 PM
Antti O's Avatar
Antti O
My problem was found
Then i have to think how to fix that.
Old Sep 11, 2009 | 08:49 AM
mercgrey's Avatar
mercgrey
its only coax isnt it mate? b n q have got the ends for sky down there and there screw fit and dead small to, i would try that first buddy!
Old Sep 11, 2009 | 09:32 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
just put a new cable in, wouldn't cost more than a tenner i'd say.
Old Sep 12, 2009 | 08:40 AM
Antti O's Avatar
Antti O
There is special connector in antenna amplifier, so i cannot use standard aerial coaxial.
And i do not now how difficult it would be change because it runs under roof trim.
I will next week find out is there some good and small connectors which i can use.
Microcat shows that there is still original coaxial available costin about 30£ so thats one option.
Dutchfordfreak
Escort Range
Aug 27, 2015 09:05 PM
dojj
Aug 25, 2015 06:56 PM
cameron2
Aug 25, 2015 07:18 AM
Daisychain
Aug 22, 2015 08:12 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
