cvh trigger kit
Sep 3, 2009 | 03:36 PM
cvh trigger kit
Where can i buy a trigger kit for my cvh? Ás i didnt drill the hole for the cps. So a trigger kit seems to be the next thing.
Sep 3, 2009 | 04:28 PM
You have PM!!
Sep 3, 2009 | 05:32 PM
www.triggerwheels.com for the wheel, and then your local motorfactors for a VR Sensor.
Sep 3, 2009 | 06:39 PM
Burton sells a whole kit. Is working very well...
Sep 3, 2009 | 07:26 PM
Seen that before. But never thought it would go together with the MS. Like to see how this one is mounted on the engine. any pics?
Sep 3, 2009 | 07:36 PM
Works fine with the mappable trijekt injection, megasquirt should be able to use this, too...?
Sep 3, 2009 | 07:47 PM
MS and most management systems will be fine with a 36-1 trigger wheel.
Sep 3, 2009 | 08:02 PM
Sep 4, 2009 | 08:02 AM
so if u use the kit from burton u dont av change the bottom pulley, belt, bracket and alternator? this kit jus bolts on right?
Sep 4, 2009 | 09:05 AM
Sep 4, 2009 | 09:08 AM
Somewhere in the 100. You are cheaper
so ill let you know
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
01782areacode ,
16 ,
361 ,
cvh ,
escort ,
ford ,
instructions ,
kent ,
kit ,
megasquirt ,
passionford ,
rs ,
trigger ,
turbo ,
wheel
