engine rebuild parts/3 dr car cover/ turbo/ diff
Old Aug 31, 2009 | 10:36 AM
Steve Escos's Avatar
Steve Escos
Default engine rebuild parts/3 dr car cover/ turbo/ diff
200 block fresh rebore to 0.5mm and unused since will need a quick once over as some surface rust from storage £450
0.5mm Mahle brand new rings £100 will throw in some used pistons to suit but can't guarentee condition as some marks visible.
All parts below are brand new and unused:
Genuine 2wd cosworth oil pump £140
4wd water pump with gasket £100
Small turbo headgasket genuine / bolts £40 PROV SOLD
Small turbo head gasket/ cometic engine set/ Bolts £100
ARP rod bolts £45
ACL Bearing kit: Mains/ big end/ Thrust standard size £65
Cambelt /Tensioner £55
2wd motorcraft 3 piece clutch kit- new in box £120
Also available:
3 Door tailored outdoor cover £80 PROV SOLD
Collins engine mounts new £150 PROV SOLD
Electric sunroof kit £55
P8 Ecu - no chip £300
P8 MSD chip to run standard comp/ T34/ 55 Blacks/ closed loop/ wasted spark. £250
T34 48 housing slight external crack on housing £300 ono
55 housing brand new £250
4x4 rear diff and driveshafts £100
front and rear calipers inc uprated discs/ pads from 3 door £200
Pics can be supplied of all parts.
Steve 07725238098
Old Aug 31, 2009 | 12:17 PM
dave cos4x4's Avatar
dave cos4x4
intrested in the 3 door cover Steve any pics of it on lol.
are the engine mounts 2wd ones yes, maybe them too.
first dibs on both,await reply for pics.
Old Aug 31, 2009 | 12:44 PM
wildheart's Avatar
wildheart
2nd dibs on the car cover thankyouplease.
Old Aug 31, 2009 | 12:57 PM
Steve Escos
Dave you have PM, car cover is a custom lightweight made by classic additions
Old Aug 31, 2009 | 02:25 PM
joe s's Avatar
joe s
Is the 4wd water pump 100 posted mate?
Old Aug 31, 2009 | 02:41 PM
dave cos4x4
pm sent back Steve.
Old Sep 1, 2009 | 07:43 AM
Steve Escos
Yes mate.
Old Sep 1, 2009 | 08:13 AM
Lo@der's Avatar
Lo@der
Passionford Thread Killer
Any info on the condition of the P8 please?
Old Sep 1, 2009 | 11:15 AM
Steve Escos
P8 was working fine when removed. Not sure what other information you want? Comes with no chip or babyboard. Or you could buy the ecu and MSD chip together for £450 delivered. The chip alone would cost around that price. Regards Steve
Old Sep 1, 2009 | 01:07 PM
M K's Avatar
M K
pics of block please mate and is it totally bare etc
also could you arrange delivery for extra cost
Old Sep 1, 2009 | 02:57 PM
Steve Escos
Block is totally bare, will upload pics in a minute. Could organize a courier or can bring to national day
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
xr4x4rs
Aug 6, 2015 09:03 PM
COLEYST200
Aug 3, 2015 08:55 AM
