Centre bush in propshaft
Old Aug 31, 2009 | 06:37 AM
2wdsaff's Avatar
2wdsaff
Default Centre bush in propshaft
The centre bush in my propshaft seems to be absolutely shafted, can pull the shaft about all over the place, any idea where i can source one of these? also is it just the rubber bush that need changing or do i have to change the bearing also?
Old Aug 31, 2009 | 10:16 AM
How much play do you have ?, as they should have some anyway.
Old Aug 31, 2009 | 08:50 PM
2wdsaff's Avatar
2wdsaff
a lot, the bush is that shot the the shaft can touch the bracket
gcfcos
59
Oct 6, 2015 05:04 PM
DavidK
Sep 27, 2015 02:55 PM
