2wd cossie problems...
Old Aug 30, 2009 | 02:38 PM
2wdsaff's Avatar
2wdsaff
Default 2wd cossie problems...
Hi Folks, just gotten my first cosworth after years of rst's etc... having a few issues with it hopefully someone will be able to shed a bit of light on them...
1st up, car idles the whole time at 2k.... however if i unplug the icv then it will idle as normal? NOW SORTED
2nd, Temp guage does not work atall... any idea where where the sender is to that? head/radiator? NOW SORTED
cheeRS
also just found the centre bush in my prop is shafted, any idea where these can be sourced from? will i need a complete bearing/rubber bush?
Old Aug 30, 2009 | 02:40 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
Check the blue plug at the rear of the head on the right hand side isnt off or broken, That was giving me the same idling issues.
As for temp i think its a wire/plug below the blue plug but i could be wrong
Old Aug 30, 2009 | 03:49 PM
Alvyn's Avatar
Alvyn
If still all standard the sender unit wire is at the front drivers side of the head!
Old Aug 30, 2009 | 04:07 PM
Ebonycossie4x4
ok sorry fellow essex boy, thought it was towards the rear lol.
Old Aug 30, 2009 | 04:23 PM
forevaford's Avatar
forevaford
4x4 its at the rear, 2wd front
Old Aug 30, 2009 | 05:45 PM
If you've just got it, I would recommend replacing the CTS or coolant temperature sender, NOT to be confused with the gauge sender, which as said on 2wd is at front of head near the shiny silver pipe that goes behind the ex manifold to the rear, it has a single wire to it.
The CTS is at the rear of the head other side under the inlet manifold, if this is saying it is too cold it will raise the idle for a cold engine.
Old Aug 30, 2009 | 08:35 PM
2wdsaff's Avatar
2wdsaff
yea i've just gotten it, been sat for 6 years so giving it a full service, belts change etc. i'll give that a try, thanks folks
Old Aug 30, 2009 | 08:54 PM
2wdsaff's Avatar
2wdsaff
Old Aug 30, 2009 | 09:23 PM
martysmartie's Avatar
martysmartie
Try cleaning ISCV, although may be bad setup.
Martin
Old Aug 31, 2009 | 10:21 AM
The iscv doesn't need cleaning as it works, this is shown by the fact that it is causing the high revs when connected, but idles ok when disconnected, the clue is finding out what is telling the valve to raise the speed.
Old Aug 31, 2009 | 10:25 AM
Ebonycossie4x4
Agreed^
mark r
Sep 29, 2015 07:27 PM
arfurski
Sep 26, 2015 10:39 AM
IainRS1700T
Sep 25, 2015 06:44 AM
dojj
28
Sep 11, 2015 10:00 PM
rsstav
Sep 7, 2015 04:43 AM
