Help Needed!!! Oil Leak!
Old Aug 29, 2009 | 07:21 PM
mattseries2's Avatar
mattseries2
Default Help Needed!!! Oil Leak!
Hello all!
My engine is all back in now after the rebuild, and 2day tried to start her up for the 1st time! after a few cranks over she started and cut out after about 5 secs, but on the 6th or 7th time she ran but oil was out from down by the oil pump! Is this a common problem? I think it may be the crank shaft oil seal or the sump gasket! Ill have a closer look 2moz and see but does anyone know how hard it is to change the crank shaft oil seal?? Because i dont really want to have to take my engine out again lol !!!
CheeRS
Old Aug 29, 2009 | 07:36 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
if it is the crankshaft oil seal, the engine has to come out, flywheel off, sump off.
Old Aug 29, 2009 | 07:39 PM
studabear's Avatar
studabear
but it it was near the oil pump it shouldn't be the seal behind the flywheel
Old Aug 29, 2009 | 07:42 PM
mattseries2
flywheel dont need to come off as its at the oil pump end...
Old Aug 29, 2009 | 07:44 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah if it's crank seal then just remove the oil pump, but i would say sump gasket as these are notorious for being a twat to get right.
Old Aug 29, 2009 | 07:51 PM
mattseries2
ok mate thanks, ill have a look at the sump 1st tomorrow!
Old Aug 29, 2009 | 08:11 PM
haz87's Avatar
haz87
You can do the oil pump end crank seal without removing the pump btw! Tho i bet its the sump gasket
Old Aug 29, 2009 | 08:16 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Oh I didnt know that!? Handy!
Old Aug 29, 2009 | 09:59 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
sorry, didn't realise it was the oil pump side (and you didn't say), can be done in situ, done a few pump changes in situ.
alternator/belts off. drop sump.
it is probably the sump like said, but to do either task the sump has to come off anyhow.
Old Aug 29, 2009 | 10:10 PM
Danster76's Avatar
Danster76
Been there. My money is on the sump. I've got mine sorted after countless attempts and tried EVERYTHING. What worked for me was PAYEN gasket - Kimbers locally supply them. No glue, silicon or anything. Fitted gasket to cleaned sump surface and offer up to cleaned block. Worked center out with a 1/4" drive ratchet nipping up then repeated tightening just a bit more. Iirc the manual says 5-8nm but when I torqued up like this it pissed out. Good luck.
Old Aug 31, 2009 | 10:33 AM
mattseries2
Thanks for your replys! Ill check the sump 1st i think and see if she still leaks!
JoeyBoyden
Aug 18, 2015 10:52 PM
st220kyle
16
Aug 14, 2015 06:13 AM
col93saphcos
Aug 7, 2015 03:21 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
mattman1234
24
Aug 1, 2015 11:46 AM
