If my brake disc is rubbing the caliper...
Old Aug 29, 2009 | 11:34 AM
TurboShed's Avatar
TurboShed
Cossiemodo
Default If my brake disc is rubbing the caliper...
4x4 Saff Cos standard front brakes.
Disc is rubbing caliper. Symptoms were "warped disc", so changed discs and pads, problem unchanged. I can see the disc has rubbed the caliper, bright metal on the caliper. With the car jacked up, I can move the wheel slightly and the disc moves slightly between the pads.
Before I waste any more money, is this a failed wheel bearing?
Old Aug 29, 2009 | 12:54 PM
iansoutham's Avatar
iansoutham
OCD Victim
Wheel bearing gone bye bye.
Old Aug 29, 2009 | 01:50 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Ok thanks, I just want to be able to confidently order the right part this time.
Old Aug 29, 2009 | 02:01 PM
dojj's Avatar
dojj
Resident Wrestling Legend
when it's off, make sure it's not rubbed through the abs sensor, otehrwise it's more hassle
Old Aug 29, 2009 | 02:28 PM
TurboShed's Avatar
TurboShed
Cossiemodo
ABS is disconnected mate.
Nov 1, 2015 06:53 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
locum8
Oct 1, 2015 01:50 PM
muzzman1
Sep 30, 2015 08:59 PM
