cosworth anti roll bar
Old Dec 19, 2004 | 08:31 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
Default cosworth anti roll bar
i have been fitting the front suspension into the mk4 escos today,iam using 93 4x4 running gear.i would like to move the front wheels back by about 25 cm nearer to the doors. i think the 2wd antiroll bar will do this,so are they 28mm dia,and can anybody confirm they are slightly shorter?
Old Dec 19, 2004 | 08:46 PM
CozzyBrom's Avatar
CozzyBrom
fit comp strut kit
Ł150 deliverd
ajust wheels where u want
Old Dec 19, 2004 | 08:53 PM
Lloyd's Avatar
Lloyd
how does this strut kit work?any pics?
Old Dec 19, 2004 | 10:01 PM
Tony Ryan's Avatar
Tony Ryan
Replaces the srd forward facing roll bar
Old Dec 19, 2004 | 10:02 PM
CozzyBrom's Avatar
CozzyBrom
i see if i can find some
basicly gets rid of old roll bar and fits in its place
depending on coil overs you wont need roll bar
or you can buy a roll bar kit aswell
Old Dec 19, 2004 | 10:04 PM
Tony Ryan's Avatar
Tony Ryan
A bladed GpA Roll bar can then be used in front of the tca's , you will need to chassis mount it or use a x-member from the early GpA Sapphire 4x4 tho .
Old Dec 19, 2004 | 10:10 PM
CozzyBrom's Avatar
CozzyBrom
cheers tony
Old Dec 19, 2004 | 10:18 PM
tiny's Avatar
tiny
If the compression struts are fixed length will that not increase bump steer ? over suspension travel ie push the weel in an arc ?
Old Dec 19, 2004 | 10:25 PM
Lloyd's Avatar
Lloyd
nice pics tony thanks i can now see how this would adjust the wheel to where i want it.my car has avo coilovers on it,but i would still need some type of antiroll bar set up i think
Old Dec 19, 2004 | 10:31 PM
CozzyBrom's Avatar
CozzyBrom
are you blind carnt u see the roll bar in the pic
Old Dec 19, 2004 | 10:55 PM
Lloyd's Avatar
Lloyd
i can see the link to the lower arm,and the blade to the chassis.but not the bar to the other side
Old Dec 19, 2004 | 10:58 PM
CozzyBrom's Avatar
CozzyBrom
Old Dec 19, 2004 | 11:28 PM
Lloyd's Avatar
Lloyd
lo you might well laugh brom but you are gonna get this car to sort out once its running
Old Dec 19, 2004 | 11:31 PM
CozzyBrom's Avatar
CozzyBrom
cool man look forward to it
Old Dec 19, 2004 | 11:59 PM
Lloyd's Avatar
Lloyd
you like a challenge then lol.i could do with booking it in with you for the end of jan for zoo rear beam and skyline box
Old Dec 20, 2004 | 12:26 AM
CozzyBrom's Avatar
CozzyBrom
yep can do that
has it been modded for rear beam
if not then rear link bars eayer and cheaper
Old Dec 20, 2004 | 12:39 AM
Lloyd's Avatar
Lloyd
it has been modded to take a standard cos 4x4 rear beam and diff.i will be fitting it this week,just to make it rolling.
Old Dec 20, 2004 | 06:11 PM
Eagle's Avatar
Eagle
Super Moderator
i want a bladed arb
how much brom?????
Old Dec 20, 2004 | 06:39 PM
CozzyBrom's Avatar
CozzyBrom
we do a copy type Ł180
a proper ford roll bar around Ł250 2nd and blades if you can get un Ł150 each
a proper ford set up wud be Ł700
Old Dec 20, 2004 | 06:46 PM
Eagle's Avatar
Eagle
Super Moderator
i got a set of your tca's also got some compression strutts .. so just missing the bladed arb now ... might have to be a birthday pressie to myself in january then ..
manuel boeckx
13
Oct 3, 2015 02:29 PM
Russ Hill
Aug 31, 2015 06:44 PM
Anutternutter
24
Aug 31, 2015 01:24 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
Aug 14, 2015 07:29 AM
