Map sensor on 2wd saph
Old Dec 19, 2004 | 08:20 PM
david's Avatar
david
Default Map sensor on 2wd saph
Where is it ???????? want to have a look at mine.
Old Dec 19, 2004 | 08:25 PM
wimwerf's Avatar
wimwerf
map sensor on 2wd saph....under the headertank...normally
Old Dec 19, 2004 | 08:26 PM
dave cos4x4's Avatar
dave cos4x4
the map sensor is on the passenger side inner wing.
Bolted low down and is ynder a metal bracket.
Dave.
ECU Monitor Enthusiast
On a cossie, it is on a bracket upside down on the passenger side inner wing
about halfway down.
Follow the black pipe from the inlet manifold.
Beware if you take it off - the inlet pipe is prone to snap off and it CANNOT
be repaired with absolute reliability.
Old Dec 19, 2004 | 08:27 PM
david's Avatar
david
Cheers guys
Simon I seen your first reply
Old Dec 19, 2004 | 08:31 PM
rst88, I saw the S2 in your siggy and thought it was for that .
Old Dec 19, 2004 | 08:42 PM
david's Avatar
david
Thought so mate
Need to change my siggy as ive got the saph as well now
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
15
Oct 7, 2015 03:43 PM
dojj
28
Sep 11, 2015 10:00 PM
