escort rs turbo smoking ...
Old Aug 26, 2009 | 08:26 PM
Matt H's Avatar
Matt H
Question escort rs turbo smoking ...
hi , iv just bort the car and its smoking blue when i come off the boost quite bad ... what does this mean ? cheers !
Old Aug 26, 2009 | 08:42 PM
The Sludge's Avatar
The Sludge
garibaldi
oil seals around turbo i would imagine
Old Aug 26, 2009 | 09:28 PM
jodyhoare's Avatar
jodyhoare
yh i agree, blue smoke suggests oil and if its during gear change ect that would suggest turbo mate
Old Aug 26, 2009 | 09:54 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Old Aug 27, 2009 | 12:02 PM
cj_rst's Avatar
cj_rst
S2 RST
Don't rule out piston rings, but more than likely turbo oil seals. Does it smoke in the mornings when first started and then keep smoking till it's warmed up a bit?
Old Aug 27, 2009 | 12:11 PM
orion88's Avatar
orion88
could be the oil seals on the head aswell id go for them first theyre only cheap to replace if u use the tool
Old Aug 27, 2009 | 03:27 PM
Matt H's Avatar
Matt H
it just smokes when i let off mate , not bad on idle etc !
cheers for help !!!
Old Aug 27, 2009 | 03:42 PM
jonny s2's Avatar
jonny s2
Turbo seals,piston rings
Old Aug 27, 2009 | 04:42 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i'd say turbo since it's when you lett off and the vacuum the exhaust produces is drawing oil out of the turbo which has oil at a high pressure.
Vincereese
Jun 1, 2023 09:14 AM
3i Jim
Nov 20, 2015 05:12 AM
Vincereese
Aug 18, 2015 03:57 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
