Ford Non RS / XR / ST parts for sale. All Ford Car parts in here. (Non RS / XR / ST ONLY please) Starting a topic requires you to have purchased a gold membership.
BIG Clearout! Loads of bits for sale!
Old Aug 26, 2009 | 07:43 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Default BIG Clearout! Loads of bits for sale!
Ford Focus ST170 Clutch & Dual Mass Flywheel – Removed from a vehicle after approx. 56,000miles. £75 + P&P.
Ford Focus ST170 Water Pump – Removed from a vehicle after 56,000 miles. £15 + P&P.
Ford Focus ST170 Power Steering Pump – Removed from a vehicle after 56,000 miles. £30 + P&P.
Ford Focus ST170 Air Con Pump – Removed from a vehicle after 56,000 miles. £40 + P&P.
Ford Focus ST170 Thermostat & Housing - Removed from a vehicle after 56,000 miles. £10 + P&P.
Ford Focus ST170 Exhaust Camshaft & Pulley – Removed from a vehicle after 56,000 miles. £25 + P&P.
Ford Focus ST170 Crankcase Breather - Removed from a vehicle after 56,000 miles. £10 +P&P
Ford Focus ST170 Lambda Sensor - Removed from a vehicle after 56,000 miles. £10 +P&P
Ford Focus ST170 Alternator - Removed from a vehicle after 56,000 miles. £15 +P&P
Ford Focus ST170 Starter Motor - Removed from a vehicle after 56,000 miles. £20 +P&P
Ford Focus ST170 Crank Pulley (Cambelt) - Removed from a vehicle after 56,000 miles. £5 +P&P
Ford Focus ST170 Crank Pulley (Auxiliary) - Removed from a vehicle after 56,000 miles. £5 +P&P
Ford Focus ST170 Coilpack Bracket - Removed from a vehicle after 56,000 miles. £5 +P&P
Ford Focus ST170 Inlet Manifold Runner Control Box & Cable - Removed from a vehicle after 56,000 miles. £75 +P&P
Ford Focus ST170 Fuel Pump Control Box - Removed from a vehicle after 56,000 miles. £10 +P&P
Ford Focus ST170 Engine Mount - Removed from a vehicle after 56,000 miles. £10 +P&P
Ford Focus RS Fuel Rail & Regulator - £20 +P&P
Ford Focus Billet Alternator Pulley – Brand New – Polished Finish. £20 +P&P
Ford Focus ST170 Main Oil Seal Carrier - Removed from a vehicle after 56,000 miles. £5 +P&P
Ford Focus ST170 Magnecor HT Leads In Red – Used but no known problems - £30 + P&P
Classic Additions Size M Heavy Duty Outdoor Breathable Waterproof Car Cover – used once indoors on my Escort RS Turbo but would comfortably fit any similar sized car. Cost over £150. £100 + P&P.
Siemens 650cc Pico Style Injectors – Brand New £200 + P&P
Bailey Focus RS Polished Header Tank, PAS Tank & Swirl Pot – Virtually as new condition £175 + P&P
AIM MXL Pista/Strada Carbon Fibre Recess Mounting Panel - £80 + P&P.
Ford Focus Genuine WRC Inlet Manifold Plenum Chamber - £250 + P&P.
Series 2 RS Turbo Complete Car Loom - No cuts, in very good condition £100 + P&P
Old Aug 28, 2009 | 10:53 AM
GTi_Tom's Avatar
GTi_Tom
£22 posted for the alternator pulley? pm me
Old Aug 28, 2009 | 06:10 PM
maccas1985's Avatar
maccas1985
PM you.
Cheers Macca
Old Aug 31, 2009 | 01:15 PM
CoupeUK's Avatar
CoupeUK
You still have the ST170 lambda? Is it the pre cat or post cat because theres 2?
Old Aug 31, 2009 | 10:37 PM
Big Will_'s Avatar
Big Will_
Post cat i believe. Will double check and get pics later this week!
Old Sep 1, 2009 | 12:25 AM
pdfbt40's Avatar
pdfbt40
File the lugs off the plug. You can use the sensor in either position then.
Martin
Old Sep 1, 2009 | 10:20 AM
CoupeUK's Avatar
CoupeUK
I'll have it! Send me your paypal details and i'll get the monies across. Whats the total including postage?
Old Jan 25, 2010 | 07:06 PM
dillydally's Avatar
dillydally
Default Thermostat still available?
hi
I need to post a Thermostat & Housing to my son in Switzerland - it's a 2001 petrol 1.8L. If this is still available:
1. would it be suitable?
2. Is it crack-free and in GWO?
3. would you be able to post it to Switzerland for me if I pay the difference?
(If not I'd send it myself)
Many thanks,
Gill
RE:
Old Feb 23, 2010 | 02:57 PM
mexicossie's Avatar
mexicossie
do you still have the alternator & billet pulley? Would you be willing to ship as I'm not in the UK & I'm looking for a set of rods for that engine.
Old May 14, 2010 | 10:47 AM
Bks's Avatar
Bks
my st170 is runnng the light 1518, do you have the inlet manifold runner still m8
Old May 14, 2010 | 10:50 AM
Bks's Avatar
Bks
or do you think i need to buy the WRC inlet manifold to clear my engine light 1518 problem m8
YODI
Aug 29, 2015 05:48 PM
track.focus'd
Aug 12, 2015 05:53 PM
Blown Hell
Aug 5, 2015 07:22 AM
Old ford
Jul 31, 2015 06:50 AM
