fan switch
Old Aug 25, 2009 | 04:39 PM
dangerousbrian's Avatar
dangerousbrian
Default fan switch
does anyone know what fan switch i can use in my s1 so the fan will cut in earlier..(earlier the better)...dont really want to wire a switch in inside the car but will if lasr resort ...cheers
Old Aug 26, 2009 | 05:48 PM
mark2's Avatar
mark2
hi
part number XEFS4 from burton power
88-79 degree fan switch using this one in mine puts the fans on in the solid section of the bottom of the guage way before the m use it durring the summer and swop back to the one above 92. degree in the winter
mark
Old Aug 26, 2009 | 09:10 PM
martinmilne's Avatar
martinmilne
is it bad to use it in winter ?
Old Aug 27, 2009 | 09:44 AM
mark2's Avatar
mark2
hi
i would not say its bad but have found it can make the car run to to cold in winter as when you have the heater fans on that cools the engine coolant too
running to cold uses more fuel (cold start valve)
mark
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
rsguy
44
Sep 29, 2015 03:29 PM
cossie330
Sep 27, 2015 04:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
