Urgent help required efi
Old Aug 24, 2009 | 10:00 AM
Danster76's Avatar
Danster76
Default Urgent help required efi
I need to know if there is a fix or ideally a part number for the servo vacuum hose or clip fitting. Its the hose which fits between the inlet and the brake servo. On my car the clip is broken holding the vacuum hose securely into the inlet. I need to get this sorted asap as its delaying a set up session just now
Old Aug 24, 2009 | 01:12 PM
Chris Latham's Avatar
Chris Latham
Parts Restoring Nutter
Think i have a spare one in the garage Dan. Let me go and check and will get back to you matey
Old Aug 24, 2009 | 08:06 PM
Danster76's Avatar
Danster76
Do you have one? still need it if so!
Old Aug 25, 2009 | 09:06 AM
Chris Latham
I found one Dan but it looks like an MFI one although not sure how different they are for the EFI one. PM me your mobile number and i will send you a phone pic of it mate and go from there. cheeRS Chris
Old Aug 25, 2009 | 10:18 AM
Chris69's Avatar
Chris69
Phone your local ford parts desk i bought a new clip not so long ago so they should still sell them- comes with a new plastic clip and brass surround to replace the new broken/worn item.
just ask for a frst item of course.
Old Aug 25, 2009 | 02:20 PM
Danster76's Avatar
Danster76
My parts desk are rubbish! anyone got a part number?
Thanks
Old Aug 25, 2009 | 04:07 PM
pipe is 7162139 but no longer avaliable.
push fitting repair 1653956 showing as avaliable
grommet 1610301.showing as avaliable
Old Aug 25, 2009 | 05:41 PM
Danster76's Avatar
Danster76
Thanks V much.
My pipe is fine so no problem there but I need the push fitting and the grommet so bullseye!
cheers,
btw engines in bits again! lol
I'll update the thread later!
Old Aug 25, 2009 | 05:50 PM
Rs-Simon's Avatar
Rs-Simon
Thats a pisser mate, what happend?
wowk
Mar 30, 2021 07:49 PM
20/20 vision
Sep 29, 2015 09:25 PM
