2litre zetec bottom end on to cvh head?
Old Aug 22, 2009 | 01:36 PM
adamhhr's Avatar
adamhhr
Researching
Default 2litre zetec bottom end on to cvh head?
hi been reading about fitting a zetec on to my xr2 head, at the moment its a standard 1.6 xr in a mk3.5 so woundering what engine mounts ill need to to fit the zetec bottom end and is there any other mods needed? thnks
Old Aug 22, 2009 | 06:37 PM
I'm not by any means certain but think there is next to no mods to mate block head, I know some std ford mounts are used with a corner cut off of one of them, pm Roosie on here as he has done this a few times.
Old Aug 23, 2009 | 10:19 AM
xrmalin's Avatar
xrmalin
If its a mk3.5 it would be an xr2i not an xr2 wouldnt it which means its easier as the later models came with a zetec engine fitted so you would just have to buy a later model zetec engine mount out of say an rs1800 and away you go.
If it is an xr2 you just use the cvh mount 2 bolt holes line up to the zetec block the third hole very nearly lines up it just a case of chopping it off re-positioning it and welding it back on.
Hope that helps you Mark.
Old Aug 23, 2009 | 10:26 AM
zvhrst's Avatar
zvhrst
stick with full zetec mate,
more power and reliability
KW-rscos
11
Aug 31, 2015 01:51 PM
Marcus L
Aug 29, 2015 02:18 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
IAN RS2k
Aug 18, 2015 07:51 PM
john_3.0s
Aug 15, 2015 07:44 AM
