Clifford cliffnet wizard cable
Old Aug 21, 2009 | 09:52 PM
392B.H.P.SAFF's Avatar
392B.H.P.SAFF
Default Clifford cliffnet wizard cable
Hi
Wonder if any of you could help me out.
I have recently purchased a new escort cosworth and need to add a new remote to the alarm as well as change a few of the settings as i do not have the valet code anywhere and the previous owner did not know it.
I know there is a cd and cable available to use to change these settings and was wondering if any of you had a cable in the Essex area i could use just to make a few changes failing this i will have to purchase a cable and CD.
Please contact me via Pm if you would be kind enough to lend me the lead.
Old Aug 22, 2009 | 07:18 AM
RS500/364's Avatar
RS500/364
Originally Posted by 392B.H.P.SAFF
Hi
I have it but in surrey dont mine someone using it but you are away sure somewere would have this cheap enough
Good bit of kit when i brought the RS500 it had 5 fobs on it only i got one and the place that i brought the car off was know for robbing cars !!
Old Aug 22, 2009 | 07:37 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
You'll need the valet code even for the Wizard software.
I'm in that position, with the 2 years my car spent off the road, I've forgotten the valet code. Well, I'm 99% certain I know what it is, but it's not working. AFAIK, the only option for me is to send the ECU to Clifford to be fully reset.
Old Aug 22, 2009 | 08:28 AM
RS500/364's Avatar
RS500/364
Sure the valet code is last 4 of the serial number
Old Aug 22, 2009 | 08:33 AM
brad's Avatar
brad
i thought you had sorted your's christian
to the op
if the valet code has not been changed from the factory setting it will be the last 4 numbers on the white serial number sticker on the alarms brain.
Old Aug 22, 2009 | 10:58 AM
TurboShed's Avatar
TurboShed
Cossiemodo
Originally Posted by RS500/364
...the place that i brought the car off was know for robbing cars !!
FAIL
Old Aug 22, 2009 | 11:01 AM
Christian and Beccy
#1 in Spelling Club
to the op
No, I have a Wizard and the alarm is working fine, as it did before, but I wanted to change some settings and have been unable to. Not had the inclination to get it reset either.
Old Aug 22, 2009 | 12:17 PM
392B.H.P.SAFF
I was under the impression from doing a bit of research that the wizard supplied your valet code from reading the data stored in the brains?????
Also read that the valet code is the 4 digit code on your brains in the middle?????
I need to get this lead asap have purchased this new car and have a new remote, need to change a few settings as well as well as checking the intellistart, the vehicle has it fitted but unsure if it has been disabled etc.
Please anyone be kind enough to let me borrow there lead
Old Aug 22, 2009 | 12:38 PM
Christian and Beccy
#1 in Spelling Club
Seriously, if you could into the system without the Valet code, imagine that? It'd be the worlds best alarm until the thief has a laptop/wizard.
You'll not get in without the Valet code, I'm 99.9% sure of that and anyone that leaves their valet code at the factory setting is asking for trouble too.
Steve Escos
Alloy wheels and ICE for sale
14
May 8, 2019 02:45 PM
mk1turboestate
Dec 2, 2015 08:31 PM
muz
Sep 30, 2015 08:29 AM
Flatlinedan
Sep 18, 2015 12:41 PM
Bransby
Sep 14, 2015 08:54 PM
