no brakes, what should i check?
Old Dec 19, 2004 | 09:05 AM
Gra's Avatar
Gra
Default no brakes, what should i check?
When i bougt the RS the brakes were shot, (been sitting fro 3yr or so, I have changed the pads and discs, but the brakes are still non existent, what should i look the change? brake lines, master cylinder? any help appreicated at leasst i have sorted the white smoke i think
Old Dec 19, 2004 | 09:10 AM
SPADGE's Avatar
SPADGE
Is there fluid in there Gra?
If so you could try bleeding them also make sure there are no leaks!
Old Dec 19, 2004 | 09:14 AM
NUTS RuS's Avatar
NUTS RuS
As above - is there any feel in the pedal at all ???
Old Dec 19, 2004 | 05:16 PM
Gra's Avatar
Gra
ther is no feel in the pedal at all to be honest
Old Dec 19, 2004 | 05:18 PM
Ginge !'s Avatar
Ginge !
just finding my feet
are the calipers seized , not uncomon for the rst brakes to sieze up
and yeah fluid is a good check too
Old Dec 19, 2004 | 05:23 PM
NUTS RuS's Avatar
NUTS RuS
Is it connected to anything ?
Old Dec 19, 2004 | 05:26 PM
Gra's Avatar
Gra
calipers moved in and out ok when i put the pads on, will pt in new fliud and bleed em
Old Dec 19, 2004 | 05:27 PM
Gra's Avatar
Gra
inever thought of that seriously it does stop eventually, just hardly at all
Old Dec 19, 2004 | 06:34 PM
NUTS RuS's Avatar
NUTS RuS
lets start with the obvious first
New fluid and a bleed will tell us something Get onto it NOW
Old Dec 19, 2004 | 08:38 PM
Gra's Avatar
Gra
Get onto it NOW
lol, this is me we are talking about, i still aint even unpacked my cossie calipers for my rear brake set up will sort it Wed (hopefully) as i am finish work on Tue for Xmas also gotta buy a bleed kit
Old Dec 19, 2004 | 09:04 PM
rswoza's Avatar
rswoza
check the plastic pipe from the inlet manifold to the servo is connected/ doesnt leak
IainRS1700T
Sep 25, 2015 06:44 AM
pabloXR
Sep 21, 2015 12:42 PM
The Enigma
Sep 12, 2015 10:12 PM
focus2351
Sep 9, 2015 09:33 PM
hopper350
Sep 4, 2015 12:53 AM
