Change oil pump with engine in car
Old Aug 19, 2009 | 12:09 PM
matthart's Avatar
matthart
Default Change oil pump with engine in car
Changing oil pump on a CVH turbo as mine is on its way out.
I've got the sump off and the oil pump free to move about, but I can't get it off the end of the crank, there just isnt enough room between the inner wing and end of the crank.
Anyone changed one of these with the engine in the car? Can i just push the engine across enough to get the pump free? Open to suggestions!
Old Aug 19, 2009 | 12:28 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i've done a few in situ, just takes some wiggling and possibly spinning it around, you need to undo the oil pick up pipe first though IIRC.
you may be best to drop the engine mount off and lower the engine a bit.
Old Aug 19, 2009 | 12:40 PM
haz87's Avatar
haz87
As above, let the engine drop slightly and with a bit of pushing and pulling it will come off
Old Aug 19, 2009 | 06:03 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Loose the pick up pipe and apply a big bar to move the engine over, works a treat!
big_Rad
Sep 15, 2017 09:36 AM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
dlwarrior
Aug 5, 2015 10:19 AM
