ST 170 - Global windows close/open and auto lock
Old Aug 18, 2009 | 10:01 PM
Shings's Avatar
Shings
Default ST 170 - Global windows close/open and auto lock
Anyone know how to do it???
Set it or whatever.
I just got a ST170 and would like to sort it.
Ta
J
Old Aug 19, 2009 | 01:49 PM
RichieST's Avatar
RichieST
Global open/close only works on some 5 doors, press and hold the unlock button on the key fob and see if it does.
As for the auto lock, search for the procedure, its a bit tricky but I've done it!
Old Aug 27, 2009 | 09:02 AM
daviddunlop83's Avatar
daviddunlop83
The auto lock can be turned on by doing this:-
Auto motion lock:
1. Turn on ignition till dash lights come on but don't start engine!
2. Lock the door using the lever on the door handle and then unlock 3 times
3. Turn off ignition
4. Repeat 2 but with ignition OFF
5. Turn on ignition - should hear a beep
6. Lock door again as in 2 BUT ONLY ONCE - final beep should be heard
7. Done!
2wdsaph ben
18
Oct 2, 2015 05:18 PM
AJC
Oct 1, 2015 06:47 PM
stevecfrst1
Sep 30, 2015 05:18 AM
rsguy
44
Sep 29, 2015 03:29 PM
cossie330
Sep 27, 2015 04:13 PM
