fuse box
the best thing to do ( if you need to remove the loom ) is to cut the pack of wires down by the drivers seat under the trim , bout 6 wres , ll colour coded and this saves you striping the back loom out ,
to actuall remove the fuse box you need to give a good tug on the panel that the relays and fuses plug into , itll come away and leave a box , there are 4 screws under this that secure the main body of the box to the car .
hope this helps ??
hope this helps ??
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
