T34, greys with standard compression Question
Old Dec 18, 2004 | 11:38 AM
MarK4's Avatar
MarK4
Default T34, greys with standard compression Question
Just wondered how much boost you can get away with on the above spec providing that it is live mapped (probably Stu or Ahmed). I was hoping to run 2 bar held with a .63 and water injection.
1. Is is possible or will the standard compression limit the amount of boost I could run?
2. How much boost from the T34 (.63) roughly will it take to max out the greys?
Thanks in advance
Mark
Old Dec 18, 2004 | 11:41 AM
alan rainbow's Avatar
alan rainbow
no problem karl will map grays 2.2 bar on standard comp
Old Dec 18, 2004 | 11:48 AM
MarK4's Avatar
MarK4
2.2 bar Don't suppose you know what the lag would be like?
Is that 2.2 bar held or spike? I take it the greys are fine at that boost pressure.
Old Dec 18, 2004 | 11:51 AM
Disabled Account's Avatar
Disabled Account
Default Re: T34, greys with standard compression Question
Thanks in advance
Mark
Mark, I would not want to use more than 26 PSI (held) boost on a standard T34........Maybe a T34 with 360° bearing could cope with more boost, say 28 PSI (held)........Either wat you would be working the turbo very hard.
Old Dec 18, 2004 | 11:56 AM
MarK4's Avatar
MarK4
Thanks for the reply, it will be at least have a 360 thrust if I can afford it it will be roller bearing. Would it be ok to use standard cams and head?
What head gasket should I use WRC?
Old Dec 18, 2004 | 11:57 AM
TIFF's Avatar
TIFF
Chasing Radders
I run a T34 .63 and Greys on standard comp, Been fully mapped by Karl and it spikes 30psi and holds 28psi and it is awsome
It reaches Full boost at 3300rpm so not as laggy as what you would think IMHO
Old Dec 18, 2004 | 11:59 AM
Stu @ M Developments's Avatar
PassionFords Creator
Heres an example:
https://passionford.com/forum/viewtopic.php?t=55787
Old Dec 18, 2004 | 12:00 PM
TIFF's Avatar
TIFF
Chasing Radders
I run a WRC Mountune 4 Layer Head Gasket
Old Dec 18, 2004 | 12:12 PM
Milko Pete's Avatar
Milko Pete
I used to run standard turbo, GpA gasket, 28psi held, did 380bhp and 398lbft, felt like a missile!
Old Dec 18, 2004 | 01:45 PM
MarK4's Avatar
MarK4
I didn't think a gpA would be sufficient? Think I will go wrc multi layer..
Full boostby 3300rpm is exceptional
Cheers for the example stu will check it out now
Old Dec 18, 2004 | 11:36 PM
Rs Craig's Avatar
Rs Craig
land of the rising sun
From: sheffield,home of james toseland world superbike champion
ALL I WILL SAY IS THAT I DROVE GUS'S CAR WHEN DONE IN THIS SPEC WITH STU AND IT USED TO GO LIKE F*CK now it has a bit more top end but back then it killed a M3 evo no probs gus runs a cometic head gasket as so do i and that aint been a prob yet its the best grey's conversion I've been in and ive been in quite a few
Old Dec 18, 2004 | 11:40 PM
how much boost you peak at isnt going to effect lag really, as you can still wind lots of timing on with the map at the bottom end of the boost spectrum.
higher cr like this will be far less laggy than if you dropped the cr too.
Old Dec 19, 2004 | 05:58 AM
MarK4's Avatar
MarK4
Well I think I have decided what spec to go for put it tha way
Do you mean the new shape M3?
Old Dec 19, 2004 | 09:34 AM
TIFF's Avatar
TIFF
Chasing Radders
I have raced both old and new shape M3 in mine and put it this why, they werent to pleased
Old Dec 19, 2004 | 09:35 AM
Deano's Avatar
Deano
Tiff does you car seriously make 30 PSI by 3300rpm ?
Old Dec 19, 2004 | 09:36 AM
TIFF's Avatar
TIFF
Chasing Radders
Yes Deano, Full boost at 3300rpm
Old Dec 19, 2004 | 09:38 AM
Deano's Avatar
Deano
When does it start tailing off mate ? and what boost is it when you change gear
Old Dec 19, 2004 | 09:41 AM
TIFF's Avatar
TIFF
Chasing Radders
It peaks at 30psi at 3300 them will hold to about 4000 where it then drops to 27-28psi and will hold through the range
Old Dec 19, 2004 | 09:43 AM
Deano's Avatar
Deano
Can I have a go
Old Dec 19, 2004 | 09:47 AM
TIFF's Avatar
TIFF
Chasing Radders
Yes mate, pop round
Old Dec 19, 2004 | 09:49 AM
Deano's Avatar
Deano
Ill hold you to that
And what you mean pop round , you aint local you know
Old Dec 19, 2004 | 09:52 AM
TIFF's Avatar
TIFF
Chasing Radders
I cant wait to see this guy walking up my drive
Old Dec 19, 2004 | 09:53 AM
Deano's Avatar
Deano
YOU FOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOKIN COOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOONT BASTID
Old Dec 20, 2004 | 12:18 PM
TIFF's Avatar
TIFF
Chasing Radders
Old Dec 20, 2004 | 12:22 PM
Paul Eggleton's Avatar
Paul Eggleton
I'm in a dilema wether to go for this next or save for the proper 400+ conversion
Old Dec 20, 2004 | 12:23 PM
RANJ's Avatar
RANJ
why have 400 wen u can have 500
Old Dec 20, 2004 | 12:24 PM
TIFF's Avatar
TIFF
Chasing Radders
Paul
Why not get it done now until the engine needs a rebuild, then get 500 ponies
Old Dec 20, 2004 | 12:28 PM
CraigN's Avatar
CraigN
i agree paul
t34 and greys goes like fook
i dont see the point in bothering with any more in my opinon of course
i cant use what i have on the road these top speed stuff doesnt interest me and car is great (will be when i sort handling and tyres) on track
good enough for me
Old Dec 20, 2004 | 01:30 PM
Paul Eggleton
I know what your saying fella, coz the transmission is going to need to be upgraded just the same at 400 as if I was running 500. I don't drive like a girl so i would break std tranmission with 400 .
Tiff, if it's coming apart for a h/g I'd go for the full monty and rip the lot out and rebuild, just to save on expense in the long run. Don't want to re-use the wrc head gasket
Old Dec 20, 2004 | 03:07 PM
Rs Craig's Avatar
Rs Craig
yes new m3 shape
Old Dec 20, 2004 | 05:11 PM
TIFF's Avatar
TIFF
Chasing Radders
I TOTALLY agree with you there Craig
Old Dec 20, 2004 | 05:17 PM
chunny's Avatar
chunny
But do you guys use your cossies everyday and through winter??
Old Dec 20, 2004 | 05:34 PM
TIFF's Avatar
TIFF
Chasing Radders
I use mine when it is dry and a nice day
Old Dec 20, 2004 | 05:37 PM
ImaRacing 700's Avatar
ImaRacing 700
...if your going 400 then why not go 500 but then saying that why not go 600 or better still 700 oh fuck it go 800 but hang on while your there go 900 or better still the magical 1000
Old Dec 20, 2004 | 05:38 PM
peteh's Avatar
peteh
So yours is a standard build with the expensive head gasket, T34, greys, cooler filter and pipe tiff?
do you know a fiqure what it produces?
Old Dec 20, 2004 | 05:53 PM
TIFF's Avatar
TIFF
Chasing Radders
Yes Pete, that is what i have
As for Figures i havent had it on a RR or anything yet as i am not too bothered. I will get it on when there is a shoot-out of some sort
But i would say it is around the 360-370bhp mark
Old Dec 20, 2004 | 05:59 PM
peteh's Avatar
peteh
And it's not that laggy? wana driveable fast car, i.e not laggy, and if it sees off new M3's i'll be happy!
umm got me thinking, is karl not mapping at all now?
do you have any pics of your engine bay? pm if you like, also when do we send our money?
Old Dec 20, 2004 | 06:01 PM
TIFF's Avatar
TIFF
Chasing Radders
My car makes full boost by 3300rpm so not that laggy really
I have still got to get some pics of the engine bay
Old Dec 20, 2004 | 06:04 PM
ImaRacing 700
Its fooking laggy compared to N/A or supercharged!
Old Dec 20, 2004 | 06:05 PM
TIFF's Avatar
TIFF
Chasing Radders
Tell a lie Pete, here is a shit quality pic i have
