jimny sj radiator
It may not be the rad at fault, but if wanting a aluminum one and have trouble finding one, just measure the dimensions, where the top + bottom hose are whether you can go thicker, longer deeper wider etc, as this opens up a lot more rads that could easily be made to fit.
I'll try to have a look later, and re post for you.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
