2wd oil dip stick tube?
Old Aug 12, 2009 | 09:13 PM
G 74F 00's Avatar
G 74F 00
Question 2wd oil dip stick tube?
Where can i find 2wd dip stick tube? Will a 4wd tube fit?
Any one got one for sale? Can find one anywhere.
Thanks.
Old Aug 13, 2009 | 07:54 AM
It's just that a bit of tube, try local metal merchants, the wall thickness might be the problem, so long as long enough you can always cut the length down.
Old Aug 13, 2009 | 08:05 AM
G 74F 00's Avatar
G 74F 00
Why didn i think of that lol. found a brand new 4 wd one but not sure weather i could use that and 4 wd dip stick? Thanks paul.
Old Aug 14, 2009 | 12:33 PM
Caution, here, make sure the total length of the inserted dipstick is the same on both, as 4wd may be a bit longer/shorter, to get a nice snug fit place tube end in a vice and make SLIGHTLY oval by squeezing slightly, then after tapping in with some decent sealer problem over.
155lee
Oct 27, 2015 04:55 AM
3doorcozmess
Sep 15, 2015 06:06 PM
dojj
28
Sep 11, 2015 10:00 PM
CrOwSoN15
Sep 10, 2015 07:33 PM
rsstav
Sep 7, 2015 04:43 AM
