2L zetec into a 1.1i mrk3
Old Dec 17, 2004 | 07:35 PM
gray fiesta's Avatar
gray fiesta
Default 2L zetec into a 1.1i mrk3
I am going to fit a 2L engen into my 1.1i car but i need to now wot do i need to fit it i have a hole mondayo as a doner ive herd that u need the 1.6/1.8 sump and oil pickup and worter pump and to modfiy a cvh engen mount but is ther eney thing else ie fule pump/tank from an 2i/rst of will mine do
Old Dec 17, 2004 | 08:01 PM
DUDE_SWEET_FRST's Avatar
DUDE_SWEET_FRST
you need lots of parts from a 1.8 zetec fiesta. all you can use from the mondeo is the engine, loom and ecu.
you will need, fuel tank and pump and lines, exhaust, all water pipes / air pipes, radiator, oil pick up pipe, oil pump, sump, probably suspension, gearbox, engine mounts, inlet. the list is endless
mayaswell buy a zetec fiesta aswell
Old Dec 18, 2004 | 10:57 PM
Project_XR2i_Trackcar's Avatar
eye wood lern 2 spel furst bfour u tri and konvurt yor engen
joking aside, i'm currently doing this to an Xr2i 8v and i'm having to source quite a few bits myself.
heres a guide that may be of use to you
http://www.fiestaturbo.com/zetecconversions
Old Dec 19, 2004 | 07:33 PM
squizxr's Avatar
squizxr
im goin to do it to me mk1 xr2!!!
have a 2.0 to go in, and a 1.6 for donor parts!!!
i still need a swirl pot n electric fuel pump!!!!
apart from that, its jus the fabrication work cos i need tpo move the top engine mount!!!!
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
focuspower
Sep 20, 2015 03:51 AM
