s2 escort spoiler question
Old Dec 17, 2004 | 05:46 PM
16vzetec's Avatar
16vzetec
Default s2 escort spoiler question
does the 90 spec spoiler fit in the same holes as the 88 spec?
cheers
mike
creedy's Avatar
creedy
yep i belive it does
The Sludge's Avatar
The Sludge
garibaldi
yes- well they did when i done mine
Old Dec 17, 2004 | 09:11 PM
Damo V's Avatar
Damo V
Only the back two... you will need to drill two new ones on the slope and riv-nut them if you want it factory...
Old Dec 17, 2004 | 09:12 PM
Billabong's Avatar
Billabong
As per Damo.....
Old Dec 17, 2004 | 10:10 PM
Stu.H's Avatar
Stu.H
no it doesnt fit the 88 spec
check tha shit
sorry
Old Dec 17, 2004 | 10:30 PM
The Sludge's Avatar
The Sludge
garibaldi
bizzare that is-mine fitted okay , no probolems at all
Old Dec 18, 2004 | 10:22 AM
16vzetec's Avatar
16vzetec
oh.
i was gonna drill holes for a 88 spec spoiler and change it to the 90 spec once i had found a good one.
bugger.
so how comes some of yu didnt need to redrill and some did??????
Old Dec 18, 2004 | 10:40 AM
ballin's Avatar
ballin
naw its not a straight swap
Old Dec 18, 2004 | 10:59 AM
apples24's Avatar
apples24
nope i removed a 88 spec other day and refitted 90 spec
top holes need redrilling, rest of holes the same before screw in top holes coat hole with grease or similar to prevent rust, seal spoiler itself with silicone to stop leaks
Old Dec 18, 2004 | 03:43 PM
Damo V's Avatar
Damo V
I can 100% guarantee, only 3 of 5 hols will line up, if you wanna just fit an 88 spec temporarily, just drill 3 holes, one for the stud in the centre and one on each side of that, on the flat section
if you scan through tony turbos thread in restorations section, there are pics on there of how I modified an 88 spec tailgate
also as apples suggests, when I fitted tonys up it was waxoiled around the holes, then siliconed around the joins, I also sprayed waxoil down the holes under the screw caps
Old Dec 18, 2004 | 03:57 PM
bassy_g's Avatar
bassy_g
are these rivnuts availible from ford?
anyone have the part no as my boot is 88spec and spoiler is 90 spec and i want to do the job properly,
any idea of finis no?
cheers
Old Dec 18, 2004 | 04:00 PM
Damo V's Avatar
Damo V
you need a rivnut gun also, 30 - 60 quid ... upwards any good motor factors, comes as a kit
Old Dec 18, 2004 | 04:02 PM
bassy_g's Avatar
bassy_g
cheers mate
Old Dec 18, 2004 | 04:05 PM
EIL132's Avatar
EIL132
Depends if you fit a copy or original
Old Dec 18, 2004 | 08:40 PM
The Sludge's Avatar
The Sludge
garibaldi
I thought i was right
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
A.t.p
Aug 15, 2015 11:37 AM
