can someone help me
Old Aug 6, 2009 | 06:33 PM
nickrsturbo1990's Avatar
nickrsturbo1990
Default can someone help me
hi there.... just been out to start my rs and it wont start it turns over fine but theres no petrol coming through wen i checkd and also theres no lights cumin on on the dash and the fuel pump doesnt make a noise....... could this be my alarm stopping this as theres a cat 1 toad alram on it???
or a fuse, or a relay ???
some help please
Old Aug 6, 2009 | 06:47 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Could be any of the above mate! Check them all out.
Old Aug 6, 2009 | 06:49 PM
nickrsturbo1990
all the fuses are ok
what relay is for the fuel???
and how do i sort the alarm?
Old Aug 6, 2009 | 06:51 PM
Jimmyc's Avatar
Jimmyc
The pink relay under your dash.
You have got petrol in it haven't you? I've fallen foul of that one before.
Old Aug 6, 2009 | 06:52 PM
nickrsturbo1990
ye got half a tank and i just put another 10 litres in 2 make sure. u no wen u usually turn ur car on u get the red oil lamp light on the dash and the pump wines well im getting none of that
Old Aug 7, 2009 | 05:25 PM
nickrsturbo1990
any one no how to sort the alarm?
nickrsturbo1990
wer is the fuel relay looked under my dash cant find it lol
Old Aug 7, 2009 | 05:27 PM
antony215's Avatar
antony215
Escort Rs Turbo
Up under the drivers side the pink one
Old Aug 7, 2009 | 05:29 PM
nickrsturbo1990
wer under the driver side
Old Aug 7, 2009 | 05:30 PM
antony215's Avatar
antony215
Escort Rs Turbo
Near the speaker cover
Old Aug 7, 2009 | 05:41 PM
nickrsturbo1990
been out to look in the car i have no pink relay under the dash
Old Aug 7, 2009 | 05:47 PM
antony215's Avatar
antony215
Escort Rs Turbo
You should have mate
Poke your head under the dash and you should see the relay pack
Old Aug 7, 2009 | 05:48 PM
nickrsturbo1990
ah ok,, how will i tell if it is the realy??
would that be stopping the ligths on my dash aswell??
Old Aug 7, 2009 | 05:50 PM
antony215's Avatar
antony215
Escort Rs Turbo
No
what alarm is it?
Old Aug 7, 2009 | 05:51 PM
nickrsturbo1990
toad cat 1 alram, the car locks and opens off hte fob, but i dont get the wine from the fuel pump wen i turn the ignition on or any lights
Old Aug 7, 2009 | 05:54 PM
antony215's Avatar
antony215
Escort Rs Turbo
What model is it?
Could be the immobiliser packed up
Old Aug 7, 2009 | 05:56 PM
nickrsturbo1990
What model is it?
duno about the model m8,
how can i get it sorted
Old Aug 7, 2009 | 05:59 PM
antony215's Avatar
antony215
Escort Rs Turbo
The only way to test to see if its the immobiliser would be to disconnect it but without knowing what model it is i cant help with that.
Old Aug 7, 2009 | 06:01 PM
nickrsturbo1990
how can i find out wt model it is, ive gt the receipt in front of me,
would producr code help?
Old Aug 7, 2009 | 06:02 PM
nickrsturbo1990
its toad Ai606
Old Aug 7, 2009 | 06:03 PM
antony215's Avatar
antony215
Escort Rs Turbo
Have you got the certificate for the alarm it will say on that what model it is
Old Aug 7, 2009 | 06:04 PM
nickrsturbo1990
its toad Ai606
Old Aug 7, 2009 | 06:09 PM
antony215's Avatar
antony215
Escort Rs Turbo
There are four black wires for the immobiliser these would need to be disconnected (but not mixed up they would need to go back how they were if its not the immobiliser)
Old Aug 7, 2009 | 06:10 PM
nickrsturbo1990
wer are these black wires
Old Aug 7, 2009 | 06:16 PM
antony215's Avatar
antony215
Escort Rs Turbo
They could be anywhere mate it all depends on where they connected them from when they installed the alarm but they will be on the ignition wiring and the fuel pump wiring. Without seeing it for myself its hard to explain it over the computer. If you send me your email address i can send you a manual for your alarm that may help you out.
Old Aug 7, 2009 | 06:27 PM
nickrsturbo1990
ye that would be great if u could do that...
what would the wires look like if i found em and would i have to cut em or just disconnect em??
