what clutch for s2 turbo engine on mk2 xr2
Old Aug 5, 2009 | 08:49 PM
saphcosworth's Avatar
saphcosworth
Default what clutch for s2 turbo engine on mk2 xr2
As the title says. as far as i know the engine is off an 89 escort turbo but not sure on the gearbox. Are they all same for 1600 cvh or is there differences?
Old Aug 6, 2009 | 11:56 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
you need to know the flywheel clutch size, being an '89 erst engine i'm suspecting series two which has a 220mm clutch plate.
so i'd get an LUK FRST clutch kit, should be good for 180-190bhp, i had one on my xr2 zvh, now on a paddle as it started to slip when i turned boost up a bit too much for it to handle.
LUK FRST clutch should set you back around £70 from a motorfactors.
Old Aug 9, 2009 | 08:44 AM
saphcosworth
OK thanks for that mate, thats exactly what happened to me lol. turned up the boost a bit higher then the old clutch liked!
Wilsfoci
15
Mar 30, 2016 10:26 PM
neil18
Mar 14, 2016 01:08 PM
