2 wd parts for sale & m.a.d engine
Old Jul 29, 2009 | 11:51 PM
tichy.cosworth's Avatar
tichy.cosworth
Default 2 wd parts for sale & m.a.d engine
hi spec front brakes 335 with 6 pots with braided hoses £750
rear set up with 328 discs and 4wd calipers and braided hoses £400
Old Jul 30, 2009 | 12:03 AM
tichy.cosworth
Default samco full set
in purple top water hoses has been cut for swirl pot turbo boost hoses is for a t34 £ 150 ono
Old Jul 30, 2009 | 12:13 AM
tichy.cosworth
Default shiny bits for sale
spec r header tank £150 ono
spec r swirl pot £60 ono
spec r power steering tank sold
cone air filter heat shield £30 ono
Old Jul 30, 2009 | 12:48 AM
derekd's Avatar
derekd
i will take the turbo heat shield spec r power steering tank mate
Old Jul 31, 2009 | 08:34 PM
tichy.cosworth
up
tichy.cosworth
up
Old Jul 31, 2009 | 08:35 PM
tichy.cosworth
up
tichy.cosworth
up
Old Jul 31, 2009 | 09:16 PM
tichy.cosworth
Default cosworth engine by m.a.develoments
i got a cosworth engine for sale built by m a developments it cost over £6000 to build it has a new block 200, new pistons low comp, wrc head gasket,ap organic clutch ,new distributor, inlet manifold ,ex manifold,blue motorsport ht leads, it was built to take 400 bhp it has not done 20,000 miles looking for £2500
this is the only pic i got of it at the mo if you are interested will take more
Old Aug 1, 2009 | 12:48 AM
mechanic28's Avatar
mechanic28
you have pm
Old Aug 1, 2009 | 07:42 AM
Matt/Escort/Cossie's Avatar
Matt/Escort/Cossie
Escort RS Cosworth
has the power steering tank gone ? if not ill take it
Old Aug 1, 2009 | 03:18 PM
tichy.cosworth
it has sold
Old Aug 1, 2009 | 03:19 PM
tichy.cosworth
Originally Posted by mechanic28
you have pm
you have pm back
Old Aug 3, 2009 | 10:20 AM
retro d's Avatar
retro d
You have pm
Old Aug 3, 2009 | 07:54 PM
tichy.cosworth
anyone
Old Aug 3, 2009 | 07:57 PM
tichy.cosworth
up
Old Aug 4, 2009 | 08:32 AM
RS500/364's Avatar
RS500/364
Rolling shell?
free to collector pm me
Old Aug 5, 2009 | 08:08 AM
Lo@der's Avatar
Lo@der
Passionford Thread Killer
p.m sent
Old Aug 13, 2009 | 05:40 PM
tichy.cosworth
up
Old Aug 13, 2009 | 05:41 PM
tichy.cosworth
up
tichy.cosworth
up
Old Aug 13, 2009 | 05:42 PM
tichy.cosworth
up
tichy.cosworth
up
Old Aug 13, 2009 | 05:43 PM
tichy.cosworth
up
Old Aug 13, 2009 | 07:52 PM
cossiedrift's Avatar
cossiedrift
What condition are the fronts in mate disc wear etc? And can you pm me best price on them please
Old Aug 13, 2009 | 10:37 PM
tichy.cosworth
ill send you some pic tomorrow
Old Aug 16, 2009 | 02:28 PM
G 74F 00's Avatar
G 74F 00
hi have you still got the cone air filter heat shield?
Old Sep 14, 2009 | 07:43 PM
tichy.cosworth
yes it is
Old Sep 14, 2009 | 07:45 PM
tichy.cosworth
still available
Old Sep 14, 2009 | 07:46 PM
tichy.cosworth
still got
Old Sep 14, 2009 | 07:47 PM
tichy.cosworth
still got
Old Sep 14, 2009 | 07:48 PM
tichy.cosworth
still got
Old Sep 14, 2009 | 07:49 PM
tichy.cosworth
still got
Old Sep 19, 2009 | 10:30 PM
tichy.cosworth
bump
Old Sep 20, 2009 | 01:54 AM
andycosworth's Avatar
andycosworth
do you still have the turbo damper?
Old Sep 20, 2009 | 09:55 AM
fordrs2005's Avatar
fordrs2005
would u sell the blue plug leads ? if so how much posted thanks
Old Sep 20, 2009 | 11:49 AM
tichy.cosworth
it has sold
Old Sep 20, 2009 | 11:53 AM
tichy.cosworth
they are going with the engine
Old Sep 21, 2009 | 07:50 PM
redzuki1's Avatar
redzuki1
Looking for the following parts for a 1990 Sapphire RS Cosworth 4x4:
- Gearknob to suit leather interior (pull off/push on)
- LH + RH seatbelt retractor foam NVH housings/pockets
- LH C-pillar fir tree clips
- LH + RH anti-roll bar mounting brackets (and bushes?)
- 2x front damper to hub bolts
- 2x front lower track control arm to hub nut+bolts
- LH + RH front standard damper top spring locator cones
- Genuine Ford leather gearstick gaiter
- 1x engine compartment cross car bulkhead top seal
All parts required in good condition.
Regards,
Alex
Old Sep 21, 2009 | 11:33 PM
tichy.cosworth
Regards,
Alex
sorry fella its just a shell i got
