MORE ADDED + pics.....cossie bits....i can bring to ford fair
Old Jul 27, 2009 | 08:17 PM
rsnissan's Avatar
rsnissan
Default MORE ADDED + pics.....cossie bits....i can bring to ford fair
Pics available on request
Chromed 3dr Grill middle brackets £10
Chromed Coil cover £10
Billet Chromed 2WD oil cap cover £5
Cam bearings £10
2WD fuel pump £40
2wd pas pipe (weeps slightly so needs a repair) £5
Kidney/flame trap box £5
2wd air box (modded for a bit more chatter!) with K&N filter £40
Ford motorcraft bottom water hose £5
P8 ECU and chip for greys £250
Powderocated Cam Pulleys £10 each
Powderocated PAS Pulley slightly bent £5
BD 14 exhaust cam 4k miles use £100
Standard Beru leads £20
Escort cosworth front splitter good condition £100
Old Jul 27, 2009 | 08:37 PM
Tony Rs's Avatar
Tony Rs
Ebony black Sapph Cos
Hello fella hope your well is this Stainless plemum injector loom tidy cover thingy £10
2wd or 4wd fitment and pics please
Tony
Old Jul 27, 2009 | 09:20 PM
giga's Avatar
giga
Hi,
Do you have the original steering wheel without air bag to escort cosworth and you can send fotos do front splitter ?
Regards
Giga
Old Jul 28, 2009 | 07:32 AM
rsnissan's Avatar
rsnissan
Tony
only pic i have is this one just infron of the battery, It was on a 2wd plenum but i think it will fit a 4x4 witha small bracket.
Old Jul 28, 2009 | 07:36 AM
rsnissan's Avatar
rsnissan
Originally Posted by giga
Hi,
Regards
Giga
no steering wheel.
pics of the splitter,
Old Jul 28, 2009 | 10:13 AM
Matt/Escort/Cossie's Avatar
Matt/Escort/Cossie
Escort RS Cosworth
Hi mate, can you tell me where you got "Stainless plemum injector loom tidy cover thingy" from? thanks
Old Jul 28, 2009 | 10:15 AM
rsnissan's Avatar
rsnissan
yeah i got it free with my last engine
Old Jul 28, 2009 | 10:28 AM
Rob Virgo's Avatar
Rob Virgo
will take the cam cover cap and intrested in the calipers.have you brakets to fit a cossie or were they ever on a ford.any pics
rob v
Old Jul 28, 2009 | 10:29 AM
Matt/Escort/Cossie
Escort RS Cosworth
oh, ok mate, ill keep looking for one then.
cheers
Old Jul 28, 2009 | 10:31 AM
rsnissan's Avatar
rsnissan
rob v
ok mate, the calipers i never got round to fitting so you will need to make your own brackets,
Old Jul 28, 2009 | 04:02 PM
SteveB's Avatar
SteveB
Texted ya......
Old Jul 28, 2009 | 04:20 PM
Rob Virgo's Avatar
Rob Virgo
will you check postage recorded to Cork and let me know how much i owe you via pm.money via paypal today.
cheers
rob v
james kiely's Avatar
james kiely
andy could i have the thermostat housing please ,could i have a price including postage to southern ireland .
cheers james
Old Jul 28, 2009 | 04:22 PM
Rob Virgo's Avatar
Rob Virgo
i will also take the polished termo please
rob v
Old Jul 28, 2009 | 05:15 PM
Rob66's Avatar
Rob66
What colour are the cam pulleys mate?
cheers
Old Jul 28, 2009 | 05:18 PM
Rob Virgo's Avatar
Rob Virgo
beat me to it james...lol
to slow typing....lol
Old Jul 29, 2009 | 03:32 PM
retro d's Avatar
retro d
Default Starter
Hello how much for the starter ?? is it new ?
Old Jul 29, 2009 | 07:59 PM
rsnissan's Avatar
rsnissan
I have taken some pictures of all the other random shite I have. I am tripping over half this crap and only want beer tokens for most of it so if there is something you need let me know...................
ALTERNATOR HEAT SHIELD
P8
2WD AIRBOX
WITH K&N
2WD LOWER RAD HOSE
T5 BOX TO ENGINE SHIELD
2WD ENGINE ARMS
ESCOS/3DR/500 CLEAR INDICATORS
2WD BERUS
INJECTOR LOOM COVER
4X4 BERUS
WATER PUMP TO RAD HOSE
CAM BEARINGS
A COUPLE OF HOSES I MODDED TO REMOVE THE WATER MODINE
SAMCO BOOST HOSE
BD14
CAM PULLEYS
3DR SOUND ENGINE BAY SOUND DEADENING
PIC OF THE AIR BOX CUT OUT
2WD PAS PIPE
PART OF A 2WD PAS BRACKET
D/V BLANKING PLUG
VAC HOSE ADAPTOR FOR PLENUM
INJECTOR CLIPS
NEW BONNET STAY SET
STAINLESS ROCKER COVER BOLTS
4X4 OIL CAP
WATER PUMP BOLT
THINK THIS IS FOR 2WD PAS PUMP
THROTTLE BRACKET
SOME SORT OF BREATHER BOLLOCKS
OIL PRESSURE SWITCH
OIL PRESSURE SWITCH ADAPTOR
2WD HEAD WATER TEMP SENSOR HOUSING
2WD FUEL PUMP CRADLE RUBBERS AND WASHERS
AUX PULLEY BOLT AND WASHER
97 DEGREEE STAT
OIL PRESSURE ADAPTOR FOR A GAUGE (1/8TH NPT)
CAMBELT FITTING KIT
SUMP PLUG ADAPTOR FOR OIL TEMP (1/8TH NPT)
WEBBER CRANCK SENSOR BRACKET
PLENUM TO ENGINE MOUNT BRACKET
RANDOM BITS OF GASH
A CUDDLEY TOY
VARIOUS QUIP INCLUDING -12 TO -10 ADAPTOR -10 TEMP SENSOR TAKE OFF BLANKING PLUGS ETC
CAM COVER BREATHER OUTLET
2WD BLANKING TRAY
2WD FILTER TO PUMP HOSE AND BANJO BOLT
SAPH SIDE REPEATERS
88DEG STAT
Old Jul 29, 2009 | 08:20 PM
rsnissan's Avatar
rsnissan
starter's gone mate
Old Jul 29, 2009 | 08:47 PM
retro d's Avatar
retro d
Default bits
Can I have dibs on the following please.
pm me the price please, i can pick up from ford fair.
*Alternator sheild
*t5 to engine plate
*Injector loom cover
*sump plug
*cam cover breather
*thermo housing.
cheers Andy
Old Jul 29, 2009 | 10:32 PM
TENSTACK's Avatar
TENSTACK
how much for the 2wd blanking plate can pick up atford fair
i guess it will fit a mk1 xr4x4 in place of the amp
Old Jul 29, 2009 | 10:47 PM
fostersice's Avatar
fostersice
is the bd14 the inlet cam and how much?
also big winged sump
Old Jul 29, 2009 | 11:52 PM
Rob Virgo's Avatar
Rob Virgo
rs,
ill also take the crank sensor braket , rubber wire seperators x 2 , and the calipers but will leave the oil filler cap.
whats the inj rail cover for ?????
cheers
rob v
Old Jul 31, 2009 | 01:33 PM
rsnissan's Avatar
rsnissan
its and exhaust cam and the sump has gone sorry
Old Jul 31, 2009 | 06:58 PM
RSCossieGaz's Avatar
RSCossieGaz
andy i'll have the d/v blanking plug! bring it to ford fair and i'll grab it off ya
Old Sep 5, 2009 | 12:25 PM
§ace§'s Avatar
§ace§
pm for you... plese reply! thanks!
interested at P8...
Old Sep 5, 2009 | 12:29 PM
STUCOS's Avatar
STUCOS
Hi mate,do you still have the part that goes in the dash below radio,see it in your pic,infront of rh sump and how much for alt heat shield
cheeRS stu
Old Sep 5, 2009 | 12:57 PM
joe s's Avatar
joe s
I am interested in the P8 and the PAS pulley mate. Will the P8 work on a 4x4 saph ok?? Whats the difference between L8 and P8. I will be running T35.63, 500 'cooler, greys etc...
Old Sep 5, 2009 | 03:06 PM
TrevCos's Avatar
TrevCos
Hi mate, have you still got the Sapphire side repeaters and wiring please? If so can you mail me a price including post to Lincoln.
ps I can pay by Paypal if you have a Paypal account.
Old Sep 5, 2009 | 05:03 PM
RS SHAUN's Avatar
RS SHAUN
pmed mate
Old Feb 19, 2015 | 10:37 PM
RSCossieGaz
Andy i know its an old post lol but you got anything left by any chance if so what?
Old Feb 21, 2015 | 07:39 PM
Cossy Mike's Avatar
Cossy Mike
As above
Old Mar 5, 2015 | 08:43 PM
1300gt's Avatar
1300gt
Default Pm
Hi I PMed you on parts mate.
Heater pipe, injector clips, turbo drain back tube if u have?
Oil pressure adaptor with twin male ends and oil pressure switch?
Can you let me know please..... Mark.
Old Mar 5, 2015 | 08:46 PM
Cossy Mike's Avatar
Cossy Mike
Thread is 5 years old
Old Mar 7, 2015 | 06:13 PM
1300gt's Avatar
1300gt
Billy_RS
16
Oct 11, 2025 09:41 PM
The Underdog
29
Sep 7, 2015 09:49 PM
Escortdriver1
Aug 5, 2015 12:45 PM
Escortdriver1
Jul 31, 2015 02:36 PM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
