breaking good spec stg3 2wd sapphire,lots of nice,new uprated parts!
Old Jul 27, 2009 | 07:05 PM
155lee's Avatar
155lee
Default breaking good spec stg3 2wd sapphire,lots of nice,new uprated parts!
car will be broken once i get people wanting the big parts,like engine,brakes coilovers etc.i am away with work from the 3rd to the 10th so from the 10th on ill hopefully be in the position where i have buyers for the high monetary items and i can get on with stripping it.the decision to break it has not been an easy 1 so i wont be letting parts go for nothing.this car is as good as new as a big part of whats on it is new genuine ford,new or powdercoated uprated parts,the very best i could find and the shell had a recent expensive respray,unfortunately the car is a cat c as it was stolen recovered before i got it,i bought it when it was released from the insurers and the only thin wrong with it was the interior was missing,no lock damage or broken glass and the alarm was still wired up and working!
bodywork first.
front bumper with rs500 style splitter and rs500 style bumper cut out,just been done and 1st class job,needs a bracket on the o/s but i have a dowell in just now and its finec/w foglamps,£400
rouse style rear spoiler,mint,£120
rear bumper,exhaust has melted the hole slightly bigger than it should be and theres a couple of holes for the mudflaps,£80
nearly new 4x4 bonnet with vents,some stonechips in the paint,£140
doors,all mint,£40 each complete except mouldings and external window rubbers
door mouldings,again,1 1/2 years old,o/s rear is a bit wrinkly,been like that from new,£140
window rubbers,no bubbling,same age,£120
rear lights and plate surround,same age,£50
front indicators,£20
morettes,slight crazing with the paint on 1 side,no cracks,corrosion,bumper strip with wiper holes filled in inc,£200
new wipers and arms,£20
new scuttle panel,£25
mudflaps,gen ford,£20
bonnet rams,nice action,£15
grill with mesh,£20
engine.
t34 with .48 housing,done around 800 miles,9 months old with receipt,came from cr turbos,think its st3 with 360 bearing,£550
green 803s,£110,same miles
msd 330 chip,26 psi boost for a 2wd,£170,very nice power spread and very driveable
group a k@n,same miles,£65
full 2wd samco boost,coolant,ancilliary kit with roose filter to t34 inlet pipe,rad to housing pipe has been cut for a swirl pot,pot inc for an extra £45£200
mongoose 2wd exhaust,mint with no dents or scrapes,same miles,£260
piper vernier pulleys,400 miles,£130
engine wiring loom,vgc,offers
all new crank position sensor,coolant sensor,inlet temp sensor,£30
bailey turbo damper,1 bolt is not an allen headed 1,£60
bailey oil breather with samco hoses,£65
bailey header tank with cap,mint, £70
2wd 205 blocked engine,not sure of miles,has 2232 stamped beside distributor,arp stud and nut head kit,new cometic head gasket,head 137.9mm thick iirc,baby blue powdercoated rocker cover,quiet strong engine,a little piston slap on start up,new stem seals and inspection last year,burns a little oil,no more than any other cossie i have owned,needs a rocker cover gasket as the new ford 1 i put on started leaking.bare engine-offers
2wd exhaust manifold,£70
magnecor leads,£35
distributor,£40
gearbox,no whines,clunks,grinding except into reverse as normal,£350
propshaft,just been painted and new center bearing fitted,£50
rear diff,all painted up nice,standard 2wd diff with a bit buffed off the top to fit in a 4x4 beam,would fit a 2wd beam with a washer,again,no noises,£200
dome motorsport camber and castor adjustable rear beam,freshly powdercoated and trailing arm rose jointed,main hope double skinned on top,£600
1400 mile old 2wd gaz gold coilovers,like new,£400
omp strut brace,2 months old,£70
pinch bolt style front adjustable rose jointed compbrake tcas,600 miles,£135
compbrake 4 pots and 350mm front brakes,pads,discs,bells,brackets,spacers and all bolts,600 miles old,£800
compbrake rear discs with new 4x4 calipers,braided hoses,new standard pads,£300
front hubs,powdercoated then had a lick of black hammerite,new bearings,pinch bolts and bearing covers,£70all shotblasted so no rusty abs rings!
rear carriers and hubs,powdercoated and with new bearings,£50
petrol tank,all painted up,no leaks,£40
rear driveshafts,new boots,painted lobros,powdercoated shafts,£45 the pair
all new bolts,washers,clips,beam mounting plates,arb brackets for the whole underside of a saph,ideal for an underside resto as i did,all new gen ford,(well 600 miles old!)£150
rear arb,powdercoated with new drop links,£30
new 2wd steering rack,600 miles and 2 months old,no leaks,new gaiters,good pipes,new track rod ends,£130
steering rack to column coupling with new doughnut,£25
interior
very good condition leather interior from a 2wd,black dash,2wd black center console,retrimmed headlining and c pillar cards in original ford material,slight shrinking on front n/s doorcard,new foams in drivers seat bolster,black carpet,gearknob,4x4 leather gear gaiter,steering wheel not included,£500
shell
expensive recent full respray in smokestone blue,recent underside resto,primered then stone chipped,no rot or rust,original arches,floors,sills etc.no welding reqd or been done,chassis number in floor,vin tags were missing when i got it so i had another set made,new heated windscreen,no accident damage,it wore all its original paint before it was bare metalled the painted blue,as mentioned its on the hpi register as stolen recovered,the cost and impossibility of finding a new interior were the deciding factors in giving it a cat c unfortunately.plate not included,offers.
there are probably loads of bits i have missed so please p.m me with what you want and ill make a list of who wants what,collection is preffered on most items but i will post,same as cash is king,paypal on smaller items or bank transfer,no swaps as theres nothing i need,trhenks for looking,lee
Old Jul 27, 2009 | 07:21 PM
col cos1's Avatar
col cos1
il take the bonnet lifters mate
Old Jul 27, 2009 | 07:29 PM
derekd's Avatar
derekd
first dibbs on these mate cheers
Old Jul 27, 2009 | 07:33 PM
RS SHAUN's Avatar
RS SHAUN
intercooler mate?
Old Jul 27, 2009 | 07:37 PM
derekd's Avatar
derekd
what rad u got too mate
Old Jul 27, 2009 | 07:45 PM
155lee's Avatar
155lee
Originally Posted by shaun655
intercooler mate?
well remembered,rs500 style,think its an airtec,it fits a sapphire with a cone filter but wont fit 1 with a standard airbox as its for an escort cosworth and the outlet is angled,i want £180 for it,the rad is sold to a friend already,ta,lee
Old Jul 27, 2009 | 07:50 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Price on the strutbrace please?
Old Jul 27, 2009 | 07:55 PM
fezzajsy's Avatar
fezzajsy
rouse spoiler and fuel line plizzz
155lee's Avatar
155lee
hi,£70 +p+p,2 months old and c/w all fixing bolts.
Old Jul 27, 2009 | 08:00 PM
Touring Car Spares's Avatar
Touring Car Spares
I'll have that when you break it please .
Old Jul 27, 2009 | 08:01 PM
CRAIG HAYTER's Avatar
CRAIG HAYTER
What ashamewhats the price on the cooler and radiator and will it 4x4?
Old Jul 27, 2009 | 08:02 PM
CRAIG HAYTER
Also price on the mo's
Old Jul 27, 2009 | 08:03 PM
CRAIG HAYTER
Turbo damper aswell
Old Jul 27, 2009 | 08:04 PM
155lee's Avatar
155lee
hi,wheels and rad are provisionally sold,cooler is for an escort cosworth,i want £180 for it
Old Jul 27, 2009 | 08:38 PM
ShiftyOldScoob's Avatar
ShiftyOldScoob
PM'd
Old Jul 27, 2009 | 08:42 PM
Mr RS500's Avatar
Mr RS500
Bugger i fancied the Mo"s for my 500
Tony Rs's Avatar
Tony Rs
Ebony black Sapph Cos
Rouse rear spoiler please if its still available i know a few people want it but thought id get in there
Tony
Old Jul 27, 2009 | 08:52 PM
Slackbladder's Avatar
Slackbladder
need some wiper arms for mine.. are they in good nick? if so ill take
Old Jul 27, 2009 | 08:53 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
ill take the oil breather asap if the other guy dont take it, Can send monet strieght \away.
Old Jul 27, 2009 | 09:00 PM
600bhp escos's Avatar
600bhp escos
first dibs on front bumper twin lamps and bonnet please
Old Jul 27, 2009 | 09:03 PM
600bhp escos
also headlinning and steering wheel??
Old Jul 27, 2009 | 09:07 PM
damian harris's Avatar
damian harris
sideways most if the time
pm'd you
Old Jul 27, 2009 | 09:23 PM
155lee's Avatar
155lee
hi,they are 1 year old and the wipers are the aero type and both have never seen rain so are like new.ta
Old Jul 27, 2009 | 09:30 PM
Slackbladder
ok mate ill take um.. paypal ok?
ahh yeah how much extra to post um?
Old Jul 27, 2009 | 09:32 PM
STUCOS's Avatar
STUCOS
Lee didnt ksa cosse say he wanted rouse spoiler ,in your for sale post last week
will take the prop mate,is beam a 4x4 beam then ? will take it ither way
cheeRS stu
Old Jul 27, 2009 | 09:38 PM
155lee's Avatar
155lee
cheeRS stu
hi,yea,beam is a 4x4 beam,only a little bit needs buffed from the top hole of the diff and a wee bit from down the side,another lad has just offered me more than what im asking for the spoiler!
Old Jul 27, 2009 | 09:39 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
pm'd
Old Jul 27, 2009 | 09:41 PM
STUCOS's Avatar
STUCOS
Lee will take beam and prop,does beam come with mounts,and when can we collect
cheeRS stu
Old Jul 27, 2009 | 09:50 PM
155lee's Avatar
155lee
cheeRS stu
hi,id rather keep the big poly bushes if poss as that would make a full set i could sell,does yours not have them?i might get it off this week if i get some of the other big things sold.
Old Jul 27, 2009 | 09:57 PM
STUCOS's Avatar
STUCOS
Nae probs lee,remind me to give you those arm bushes back at same time,just gives a shout and will come up for beam ,and prop
cheeRS stu
Old Jul 27, 2009 | 09:59 PM
RSGUESTY's Avatar
RSGUESTY
I will take the swirl pot, gen mudflaps. cheeRS adam
Old Jul 27, 2009 | 10:13 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
wheels and morrets if they not gone
Old Jul 28, 2009 | 03:34 AM
oohogwash1's Avatar
oohogwash1
how much for rear drive shafts delivered to norfolk if not already taken ?, please pm me
Old Jul 28, 2009 | 07:46 AM
Simmo's Avatar
Simmo
I'd possibly have the head if you were to break down engine and be able to send it?
Old Jul 28, 2009 | 12:29 PM
creator's Avatar
creator
how much for turbo and injectors delivered mate
Old Jul 28, 2009 | 01:06 PM
mechanic28's Avatar
mechanic28
you have pm chap!
Old Jul 28, 2009 | 01:39 PM
fezzajsy's Avatar
fezzajsy
complete fuel lines price please as i dont think i will be getting the spoiler
Old Jul 28, 2009 | 03:28 PM
RS SHAUN's Avatar
RS SHAUN
i'll have the amal valve bracket pal, paypal?
Old Jul 28, 2009 | 06:13 PM
155lee's Avatar
155lee
hi,£670 delivered,ta,lee
Old Jul 28, 2009 | 06:15 PM
155lee's Avatar
155lee
yeah,i wish i had 6 spoilers!now my pal is showing an interest in it!the fuel lines are from matt lewis,rubber with overbraid,anodised jubilee clip ends,2 months old,less than half price,£65,ta,lee
