700 bhp Zetec???
There’s a US engine builder calming to built a 700bhp zetec engine on a budget. I think he is talking a load of BS but don’t know zetec engines well at all to call him out on it. The builder is being a complete ass and not telling anyone the spec and has not published the dyno result but a few people have claimed to have seen the dyno result and say it is legit. Is it possible to build a 700bhp zetec turbo? Also what sort of cost would be involved and parts?
everythigns possible mate ,
theres at least two zetecs in the uk with over 500 hp , both lads frequents this site, im sure they can help with specifics regarding prices ,
as for 700 hp .
could be done , if hes running it on race fuel and fuck off hugeeee turbo , slam a bucket load of boost through in one spike ,
it will make the numbers , but may not be useable ,
see what you can dig up over the pond fella
try searches on the web ect , if its a tuner it my be on youtube ,
as for 700 hp .
quick search revealed this ,
http://www.focusfanatics.com/forum/s...d.php?t=205671
they mention a 700 hp zetec ,
but i only looked on first page ,
maybe you could read the rest ,
LOL, I am the user by the name of "English" on that thread. If you read all the pages the user 1turbofocus (Tom) is the one who claims he made 700bhp. I understand if you put enough money into a project you would get the results your after, but the user 1turbofocus (Tom) I just feel is bull shi*ing the questions he is being asked.
Also he say 800bhp out of a yb doesn't impress to him as he has made over 700bhp out of a zetec but wont post the engine spec or dyno.
http://www.focusfanatics.com/forum/s...=205439&page=2
Ever since I’ve moved to the US most message boards I’ve joined are full of bull shi*ers and this one I’m finding hard to believe as he is a respected zetec tuner in the US so I am not sure what to believe.
http://www.focusfanatics.com/forum/s...=205671&page=5
half way down that page post by focus_3xz mentions somebody called Shaun Carlson
and a 1000bhp zetec anybody ever heard about that before?
If its a 1000kg car then its gotta be over 500bhp I would think to make that sort of terminal, especially as auto transmissions sap more power than manual.
What does it weigh?
If its 1200kg+ then its gotta be 600bhp at least I should think
Some of the rallycross cars were running about 660bhp with the zetec motor a few years ago in the UK.
If they use the ST170 / SVT engine they could get the numbers but the head would start to lift off the block above 600 unless they redrilled the block and installed thicker head studs.
At that sort of level you need to have a big budget motor, no question or it will last 2 mins.
Some more info from the "700bhp" zetec
2.0 Zetec
Turbo was a Custom Big shaft Inovative TBB Turbo (lots of boost)
Forged Pistons .020
Crower Billet rods
Focus-Power Head
Stock crank
Stock Block O-ring
Adj cam gears
Stock Cams
Focus-Power Billet mains
Lentech ATX for Turbo , trans break ,2800 stall Conv, Man Valve Body
Post number 50
700bhp on a stock crank????
2.0 Zetec
Forged Pistons .020
Crower Billet rods
Focus-Power Head
Stock crank
Stock Block O-ring
Adj cam gears
Stock Cams
Post number 50
Still making good power if its doing 134mph on the quarter
What does it weigh?
What does it weigh?
OK
I believe it is 600 hp
.. but not 700 WHP (800 crank)
I do not think so .....
Specky did 138mph in his tigra on 505bhp
afew more clues
96lb injectors , Diablo chip, Focus-Power tuning c116 fuel
post 58
post 58
afew more clues
post 58
post 58
95% D.C(8k RPM)......550Hp.....
now run 1600ccm
and I am not 800HP .....
maybe 600-650...
I'm not familiar with running auto transmissions on a chassis Dyno, but he claims that they couldn't get a torque figure, and the dyno plot supposedly shows power vs elapsed time, not rpm. Now as a dyno works by measuring torque...
Then the RPM of the engine is used to translate between that figure and torque at the engine by taking the gearing out of the equation.
If they didnt have an RPM signal from the engine, they could still plot power, based on the torque and rpm of the drum, but they couldnt plot engine torque or engine power versus engine rpm
So it sounds perfectly reasonable to me that you could end up in that situation
