MONDEO 2.0 TDCi Titanium 2007 that wont start
Old Jul 22, 2009 | 09:14 PM
auto's Avatar
auto
Question MONDEO 2.0 TDCi Titanium 2007 that wont start
Hi every body
I have a MONDEO 2.0 TDCi Titanium 2007 that wont start the ignition lights are on when I turn the key noting happens apart from a relay buzzing in the fuse box under the bonnet the battery is good. Any ides? Help!!
Thanks for your help it appears to be the pre glow relay K70 that’s buzzing I would be very grateful for any more advice. Thanks again
Old Jul 22, 2009 | 09:23 PM
st3v3's Avatar
st3v3
mate try joining this forum > http://www.fordmondeo.org/forum
These guys eat and breath Mondeo so im sure will be able to help you.
Old Jul 22, 2009 | 09:43 PM
FRS-0197's Avatar
FRS-0197
Vinny
fuel pump relay ?
Old Jul 22, 2009 | 09:57 PM
RichieST's Avatar
RichieST
Originally Posted by FRS-0197
fuel pump relay ?
The engine would still crank over though wouldn't it?
I presume the car is still in its warranty period?
Old Jul 23, 2009 | 06:33 AM
The DIVA's Avatar
The DIVA
Is it a manual ?.....
Common problem if it is, the dual mass flywheel starts to come to bits and fills the starter with metal filings and jams it up..... you can strip the starter and blow out the crap and it`s as good as new, happened to mine 3 times before i fitted a new flywheel and clutch...
Don`t go to the dealer though, my mate did and ended up with a bill for a new starter and clutch and flywheel of nearly Ł1300
I bought a clutch/flywheel kit for Ł350 and got a local garage to fit it for Ł150, then cleaned out the starter myself.... all sorted as good as new for Ł500
Old Jul 23, 2009 | 06:42 PM
James's Avatar
James
new mondeo or old mondeo?
if a new mondeo i suspect it's imobilised. probs abs module concern.
Old Jul 23, 2009 | 08:00 PM
auto's Avatar
auto
Hi
Thanks everybody for your help it is a manual and it’s the last of the old shape. How do I check the immobiliser and the abs module?
Thanks again
Old Jul 23, 2009 | 08:06 PM
James's Avatar
James
hmmmm, what i wrote above applies to the newer model, not sure what to suggest really!
Alun Gregory
Sep 6, 2015 09:40 AM
JoeyBoyden
Aug 18, 2015 05:56 PM
