has anyone tryed taking the actuator signal from the plenum
Old Jul 21, 2009 | 08:16 PM
jp indy3's Avatar
jp indy3
Default has anyone tryed taking the actuator signal from the plenum
has anyone done this?its ment to let the turbo spool up as much as it wants untill the boost hits the plenum,i think.is it worth doing?
Old Jul 21, 2009 | 08:24 PM
Mark Shead's Avatar
Mark Shead
Actators are not designed to have a vacuum so you should only pressure them.
Mark
Old Jul 21, 2009 | 09:04 PM
Touring Car Spares's Avatar
Touring Car Spares
Mark
Unless you balance both sides , also acts as a very reliable boost control .
Old Jul 21, 2009 | 10:53 PM
Ian M500COS's Avatar
Ian M500COS
I had a twin-ported actuator linked to WRC boost solenoids with a feed pipe going to the inlet plenum!
It was done to help improve turbo response. Concept taken from the WRC cars.
RB26DETT
17
May 27, 2016 11:26 AM
blackbeautyzetec
Aug 29, 2015 02:11 PM
Aug 20, 2015 09:21 PM
jay030787
Aug 17, 2015 06:16 PM
no1trancefan
Aug 4, 2015 12:48 PM
