Rs 2000 on megajolt
Old Jul 20, 2009 | 09:37 PM
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
Question Rs 2000 on megajolt
I am looking to run an rs2000 i4 engine on bike carbs in my sierra track car. I want to run it on megajolt, but there is a difference regarding coil packs, so can this engine be run on a zetec coil pack, or does it need to run on the original setup?
Old Jul 20, 2009 | 10:26 PM
Icurus's Avatar
Icurus
I have an RS2000 mk5 track car thats converted to run a Zetec coil pack.
The RS orginally had 2 packs using 4 wire, but 1 of those was split into 2 and ran to each coil pack, this is the common earth/return for each coil. When using the 'single' zetec coil pack you only need 3 wires, so just turn that one back into a single and it will work just fine.
On the zetec coil pack the middle terminal/connection is the earth/common return btw
Old Jul 20, 2009 | 10:27 PM
jamieRST's Avatar
jamieRST
megajolt????
Old Jul 21, 2009 | 08:36 AM
BRIGSPORT's Avatar
BRIGSPORT
Cheers icurus.
Jamie, megajolt is an ignition only ecu.
Old Jul 21, 2009 | 08:48 AM
GARETH T's Avatar
GARETH T
if you havent bought the bike carbs yet, why not go to full hog and run some type of electric injection aswell?
Old Jul 21, 2009 | 09:00 AM
BRIGSPORT's Avatar
BRIGSPORT
I would love to go the throttle body route, but i already have the carbs, and i'm between jobs at the mo, so money is tight.
gambo08
Feb 4, 2016 10:49 PM
little bram
Sep 27, 2015 07:45 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
