starter motor problem
I have finaly got around to starting the engine but the car won't crank over. You can hear the dog coming out to ingage the flywheel but it just makes 1 click. I gave it a smack with the hammer but no luck. I found a spare one and changed it over to see if that worked but still no luck? Its a 1600 cvh.
Do you think it could be bad earth?
Im using a efi flywheel is it different starter?
The big earth to the gearbox back to the battery is on and tight and that is also connected to the body. i have also got another from the gearbox to the body. Its very strange.Also forgot to mention That it has a full battery aswell. Its sounds like it has a flat battery and only has the power to just tickle the dog gear across lol.
Russ Payne
Sep 25, 2015 08:29 PM
