Fiesta heater stuck on hot
Old Jul 20, 2009 | 06:26 PM
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
Default Fiesta heater stuck on hot
The heater on my fiesta courier van is stuck on hot when you turn the dial to cold. I've had the stereo out and it looks like the heat/cold dial is wired. Is there a valve somewhere or an electric flap? Its an s reg diesel.
Old Jul 20, 2009 | 06:28 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
heater control valve needs changing. Common fault on many fords of that era that use the same valve.
Old Jul 20, 2009 | 06:39 PM
Dal_'s Avatar
Dal_
What Warren says ^^
Looks like this at the back of the engine bay with the L and R pipes connected:
Be sure to get the latest one as there are many dodgy batches out there. This is the latest part number:
Old Jul 20, 2009 | 09:33 PM
BRIGSPORT's Avatar
BRIGSPORT
Thank you very much, the above answers all further questions.
Old Jul 21, 2009 | 08:41 AM
BRIGSPORT's Avatar
BRIGSPORT
Just checked the van, and the valve has been removed, and straight connectors used to re-connect the matrix, probably because it was stuck on cold.
Thanks once again for the replies.
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
muz
Sep 30, 2015 08:29 AM
