Master cylinder...where from??
Mine weeps ever so slightly so set my sights on getting a new one but can't quite believe you can't get them anywhere new anymore! Seem to be able to get pretty much anything else but something as significant as a master cylinder i can't find anywhere! Obvously i don't want the small 22mm one from a povert spec escort, anyone know of anywhere i might be able to get a 25mm genuine rst master cylinder from??
bit difficult to get an rs turbo cylinder these days. Most are the 22 or 23 mm cylinders.
I use a company called mlc for bits like that. If you want their number it's 01772 821000.
Has the same prob when I did my cossie brake conversion and abs removal! I ended up getting a reseal kit from a company called Big Red. They specialise in caliper/cylinder rebuild kits. Just search online for them. Hope this helps!
