EFI Accelerator Pedal??
Old Jul 16, 2009 | 04:28 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default EFI Accelerator Pedal??
This doesnt look right to me but came from a XR2i.
Can anyone confirm it's what I need fo rmy EFI conversion?
Thanks!
Old Jul 16, 2009 | 05:23 PM
crazycage's Avatar
crazycage
why dont you just run a cossie throttle body ??
Old Jul 16, 2009 | 05:25 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Because I have a FRS one that came with the inlet manifold etc.. Whats that got to do with my pedal, does it use the MFI cable fitment?
Old Jul 16, 2009 | 05:27 PM
crazycage's Avatar
crazycage
yes
Old Jul 16, 2009 | 05:30 PM
nigel b's Avatar
nigel b
no it isnt the right pedal
ill get a picture up later for you
Old Jul 16, 2009 | 06:28 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Bollocks!!!!!!
If you have a picture of the right one that would be handy, or even better one spare!!!
Old Jul 16, 2009 | 07:01 PM
project rs's Avatar
project rs
karlos that is some shocking carpet you've got there
Old Jul 16, 2009 | 07:17 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Rented house cant change it!
Old Jul 16, 2009 | 08:23 PM
rstdave's Avatar
rstdave
Efi pedal looks exactly the same as the original pedal just with a different end to fit the efi throttle cable. Not that easy to source but someone's bound to have one lying about!
Old Jul 16, 2009 | 08:43 PM
nigel b's Avatar
nigel b
this is what you need!
cut part of your new pedal off and weld it to the old one
Old Jul 16, 2009 | 08:45 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Cheers but my pedal is plastic!!! lol
I'll just have to get another one!
Old Jul 16, 2009 | 08:55 PM
Rick's Avatar
Rick
All i did was cut a small slit in the mfi one and then secure it with a tie wrap - easy.
Old Jul 16, 2009 | 09:02 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah i'm just going to buzz a piece on the end, drill a hole, cut a slit, job done!
Old Jul 16, 2009 | 09:15 PM
Garage19's Avatar
Garage19
Was about to say. Would take me two secs to sort that if thats all it is. If you get stuck pop it over.
Old Jul 16, 2009 | 09:47 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Cheers Doug, it should only take me 10mins!
I'm hoping to fit everything this weekend so will be in contact soon for some mapping fun!
Old Jul 17, 2009 | 06:47 AM
Antti O's Avatar
Antti O
Karlos
Even here is it pretty easy to find suitable pedal.
And i bet there in uk are couple more escorts.
I dont believe tie wrap "patents", get one which is proper. Or change it afterwards.
What scrappers said?
mk1turboestate
Dec 2, 2015 08:31 PM
IainRS1700T
Sep 25, 2015 06:44 AM
landaqmabba
Sep 15, 2015 07:16 PM
Marino
Sep 12, 2015 11:10 AM
dms04
Sep 11, 2015 01:57 PM
