bumper removal on a saphhire
Old Jul 13, 2009 | 06:38 PM
Kam B's Avatar
Kam B
Default bumper removal on a saphhire
will be looking at doing this to tidy up the lights etc etc
where are the bolts and or clips
cheeRS
Old Jul 13, 2009 | 06:45 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
on the front there is a bolt(13mm head) just in front of the wheels (top corner)
and at the rear there are 2 torx bolts in the boot and a 1/4 turn clip in the top corners just behind the rear wheels
Hth
Old Jul 13, 2009 | 07:51 PM
AndyPen's Avatar
AndyPen
... next question, how do you best get it off if the nut is just spinning around???
Old Jul 13, 2009 | 08:03 PM
Kam B's Avatar
Kam B
cross threaded? damm
cut it off id say, i dont know how it looks under there so i couldnt advise
angle grind it off!
Old Jul 13, 2009 | 08:11 PM
If just spinning, as is normal, grind head off, turn plastic piece in "winglet" 1/3 turn and then just push out.
Old Jul 13, 2009 | 08:13 PM
Matt Baxter
Back in black!
I take it you are on about the fron bumper
well if it was me i would drill out the rivets behind the bumper insert and the ones on the under side oh and the 1 in the end then you can get the bumper off and then get to work on the spinninng thread
hth
Old Jul 14, 2009 | 12:15 AM
AndyPen's Avatar
AndyPen
Thanks folks, dont plan to remove it just yet as no need as such - but now I'll be ready for it when I get started after the summer.
gambo08
Feb 4, 2016 10:49 PM
Orion_Gav
Sep 29, 2015 04:50 PM
rsguy
44
Sep 29, 2015 03:29 PM
