4wd cilinderhead, turbodamper/exhaust manifold?
Old Dec 14, 2004 | 09:31 AM
cozzie4d's Avatar
cozzie4d
Default 4wd cilinderhead, turbodamper/exhaust manifold?
Hi all.
As I'm rebuilding my cosworth engine (sierra 2wd), I bought a new 200 block and a "thick" 4x4 cilinderhead.
Now I still have my 2wd exhaust manifold, turbo and turbodamper,
but the 4x4 cilinderhead has no "ears" to attach the turbodamper, because the 4x4 didn't have a turbodamper anymore.
Does someone have experience with this "conversion", so I can still use my "2wd" t03 turbo? (And possibly the exhaust manifold to)
Thanks for the reactions.
Old Dec 14, 2004 | 10:05 AM
Sheldy's Avatar
Sheldy
As far as i underestand it to use the 2wd manifold with the 4x4 head you have to use a special turbo damper which i believe spec-r can supply
Old Dec 14, 2004 | 02:19 PM
cozzie4d's Avatar
cozzie4d
Does this mean that with the Spec-R or Bailey turbodamper, I can still use my 2wd exhaust AND standard t03 turbo (and in the future T34,T35 of T38 turbo)?
If so, do I need to make sure other things will be done, because my plan is to go to just under 400bhp.
Old Dec 14, 2004 | 02:22 PM
STUCOS's Avatar
STUCOS
you will find no need for turbo damper at lower power,but as said above bailey do a kit for a 4x4 head
cheeRS stu
Old Dec 15, 2004 | 06:53 AM
foreigneRS's Avatar
foreigneRS
Testing the future
the turbo damper is nothing to do with power - it's to do with vibration of the manifold. if you use a 2wd manifold, you must use a damper of some sort.
you have 2 options:
1) there is a fancy damper from one of the makers of shiny bits (could be spec R) that has a tripod looking thing that bolts on to the top of the rocker cover.
2) mike rainbird sells a bracket to bolt on to 4x4 head sto allow the use of a std damper. see this thread:
https://passionford.com/forum/viewtopic.php?t=88205
i will be going for option 2, as my project car has nowhere for the damper to fit to (i'm not sure if it's a 4x4 head, or if some twat just cut it off).
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
A.t.p
Sep 29, 2015 05:04 PM
caprixpack
Sep 25, 2015 07:53 PM
wheelwizardrefurbs
Sep 21, 2015 06:42 AM
