WET SPARK PLUGS?
Every time i start my Turbs up it miss fires for a couple of seconds and then clears i have had the car tuned up and it is chipped. I havent used my turbs for about a week and a half and on Sunday morning i decided to take my spark plugs out to give them a clean before i start it and discovered that every spark plug was wet. But it smelled like petrol so i had a thought that my injectors could be leaking and the cylinders are flooded which could be the reson why the plugs are wet and it miss fires every time its started. The last time i took my car to Power Engineering i was adviced to get new injectors. I was wondering has anbody had this problem before and might know the reson for this any advice on this would be much appreciated as my Turbs is drinking quite alot CHEERS
deathrider666
Sep 28, 2015 06:12 PM
