gotech mini x
Old Jul 8, 2009 | 01:51 AM
craig2351's Avatar
craig2351
Default gotech mini x
I am thinking of buyin gotech mini x ecu and loom, ive been told that it will get rid of my old mfi and ecu stuff but what i wana know is what injectors, manifold, etc would i need to use or could i use my inlet, cheers
Old Jul 8, 2009 | 07:50 AM
G420 DEL's Avatar
G420 DEL
id imagine youd need to go down the EFi route. fiesta turbo inlet, cps sensor.
not just a case of remove old management and put new in.
Old Jul 8, 2009 | 09:36 AM
bezo's Avatar
bezo
powered by K26
you can adapt the mfi inlet by opening up the injector seats, then use a fez turbo fuel rail and reg, youll need to weld on some sort of posts to hold the rail though.
the efi inlet can be used but if youre going to be keeping your mfi head youll need a conversion plate as the mfi head doesnt have the cut outs for the injectors.
injectors wise, all depends on what sort of power you want.
Old Jul 8, 2009 | 07:41 PM
craig2351's Avatar
craig2351
I notice your from sitech racing, if i was to send you my inlet etc could you open the injector seats for me
Old Jul 8, 2009 | 08:34 PM
stuartrsturbo's Avatar
stuartrsturbo
Why not ring Jamsport im sure they will answer any questions you have. Also they can mod your inlet
Old Jul 8, 2009 | 09:39 PM
stuart collins's Avatar
stuart collins
mini x runs off the dizzy , mod the inlet to take the injectors and away u go
Old Jul 8, 2009 | 10:26 PM
G420 DEL's Avatar
G420 DEL
sweet, thats now bad goin then! could get a spare off ebay get it sorted so you can still use your car then when all work been done chuck the inlet on.
Old Jul 8, 2009 | 10:39 PM
Raj_FRST's Avatar
Raj_FRST
Half Rice Half Chips
look on jamsport website, the have a breakdown of all the parts required, simply choose the ones you can source then the ones you need supplying phone jamie and sort a deal
Beige - 180 bhp - 210 bhp (18psi)
Greens anything above as a ball park figure, i sold my beiges as they couldnt fule anything over 14psi with about 200bhp but this was due to it being a 2.1, I bought a set of green for 100 of Tabetha which will easily fuel up to 300bhp, but I have been told they can be a bit crude, newer injectors such as vauxhall vxr injector have a more refined pulse.
I hope this helps
Old Jul 10, 2009 | 11:49 AM
bezo's Avatar
bezo
powered by K26
pm sent
Old Jul 10, 2009 | 07:24 PM
c.fogarty's Avatar
c.fogarty
Had one of the first Mini X ECU in the country on a RST. Was simple to fit & as said just a case of machining inlet for injectors (i used a 16i inlet with green cossie injectors) & using a FRST Fuel Rail.
Base map was shite, but had it mapped at Jamsport & was sweeeet!
Old Jul 14, 2009 | 05:00 PM
Ford RS Enthusiast's Avatar
Ford RS Enthusiast
Power
when you connect up gotech mini x is it a dash out job or do you just wire in up to the wiring in the engine bay ?
carlo
24
Oct 5, 2015 08:20 PM
SMILER258
Sep 28, 2015 09:04 AM
Russ Hill
Aug 31, 2015 06:44 PM
155lee
14
Aug 22, 2015 12:15 PM
