white 3 door
The car has 1years MOT,81000 miles all MOTs to prove mileage
And tones of bills
want £9000
Car is only used as summer car only ive covered 4500 miles in 5 years and it's been well maintain
Spec
200 block
Small port head with bd14 outlet cam with iski double value springs
Mongoose full system with front box cut out and 4inch tail pipe
T34/63 exhaust 247 shaft
-31
Mahle pistons with vale cuts
Shotpined con rods
Grey injectors
Organic cluch
P8 ecu with ALS btc petel board and chip to match, pecks in 5 gear at 27 psi holds 25 psi (havey Gibbs)
Erl water injection system 2D, with loom built buy uk car looms
044 fuel pump
Group A head gasket
3 bar
Group A k&n
Light weight pulleys
Pro alloy rs 500 intercooler, radiator and fans all bought as same time
Coil pack
Full loom engine loom buy car looms uk
SECS monitor
Rebuilt alternator and starter motor
Motorsport ht leads
Ap 4 port 330mm front brakes
Polly bushes all round
Rear shocks koni
And a few other little chrome bits under the bonnet
Engine was rebuilt about 2 years after i bought the car (bought the car on 76000miles) just the top end including turbo, 2005
Then a year after 2006 found out that then main seal was leaking but bottom pulley would not come off so thought f**k it rebuild the bottom end so that's when I had new block and other bits
Then 2007 done greys, coil pack, ALS turbo conversion and because im a tart i had engine out to clean it and respray under bonnet redone the throttle housing inlet manifold and rocket cover and make extra caution 4 ALS turbo, heat matting around Brake servo and added rebuilt starter motor and alternator, light weight pulleys' all new gaskets from mike rainbird new water pump, oil filter, pro alloy rs 500 intercooler, rad and fans, Also had recon box bought from touringcarspares
then fitted a secs monitor and 8 months ago
Any question please message me or email sydneyvon@hotmail.com
cheers
ps the engine looks better now ive put on a chrome oil filler cap and in the picture that is not the group A filter but there is one on it
wing is not different just, how the pic came out
had loads of interested but I’ve been a lazy in getting back to people had, to many messers 2 views, 1 off then was a bit of a disaster because the ignition amp broke so I was only running two cylinders I think put him off
what shape is the inside off the car in mate , whats the dash like is it un cracked and whats the seats and the head lineing like???
thanks steven..
thanks steven..
The only person that i knew that drove a rusty escort but called it a real race car, was a man that looked like a bear and use to chase off the kids on the easte. He then he moved to the woods some where because the kids where to fast for him.
It is a really nice car and simon has done a good job with it and he's a desent bloke, the car has gone to good home and will be well looked after!
Is this the same car???with the head gasket gone??
http://cgi.ebay.co.uk/FORD-SIERRA-RS...d=p3286.c0.m14
Not yet although i'm desperate to change them....
I realy want the compomotive CXN's but there loads of money new and can't find a set second hand
I've seen some similar one's that are a lot cheaper....I don't know weather to settle for cheaper ones as i really dislike the ones that are on it or save up and wait to get the comps!
what about a cheap opion for now and get them painted???
