engine
Old Jul 6, 2009 | 07:35 AM
GpA4x4's Avatar
GpA4x4
Default engine
High compression lightened and balanced bottom end built into 200 block, 6 long studs, lightweight matched flywheel etc etc, polished and ported head (nick waples) with matched inlet manifold on unskimmed head, believed to be re-profilled cams and fitted with mountune verniers. Very little use, temp strips are still on core plugs! Originally built and mapped by Harvey Gibbs SOLD
T34 turbo on .60 housing, 360 bearings and Mar-M 247 shaft, 0 play in shaft having only done 500 miles. Fitted with 34mm restrictor, actuator etc SOLD
P8 ecu modded for coilpack, air 2 air, ISS & ALS
ALS throttle body with mountune P8 idle valve and re-located TPS SOLD
-6 fuel rail with regulator, 4 grey injectors
coilpack and leads, as new only used for 2 hrs!
aircraft spec engine loom from SCS, beautifully made, 2 hrs use SOLD
Basically a complete engine package to fit into whatever you want, will come with map sensor, ign amps etc, basically everything to install and get it running.
Head is off for inspection just now and all is looking sweet.
I used it in my rally car and it was a good strong torquey enigne, was circa 300bhp and 400ft/lb. Obviously it'll remap without restrictor to give a piece more
Looking in region of 4k but no sensible offer refused to get the space back!!
Old Jul 20, 2009 | 08:24 AM
GpA4x4's Avatar
GpA4x4
This engine is now being split, will itemise parts soon but PM if anything specific is of interest to you.
Old Jul 20, 2009 | 09:04 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
How much for the turbo please mate?
Old Jul 20, 2009 | 09:49 AM
oohogwash1's Avatar
oohogwash1
can you send me spec and price for head pls
Old Jul 20, 2009 | 10:31 AM
GpA4x4's Avatar
GpA4x4
PM's replied too
will get pics later today
cheers
Old Jul 20, 2009 | 10:51 AM
RSGARETHW's Avatar
RSGARETHW
always working
you have pm
Old Jul 21, 2009 | 04:32 PM
STUCOS's Avatar
STUCOS
Engine and turbo staying in scotland
cheeRS stu
Old Jul 21, 2009 | 06:58 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
lots of goodies there
pm'd
Old Jul 21, 2009 | 07:17 PM
GpA4x4's Avatar
GpA4x4
All PM's replied too!
Old Jul 21, 2009 | 07:47 PM
STUCOS's Avatar
STUCOS
James woundering whats the thicknes of your recored rad,and would it fit with my 500 cooler,is lack of space for fan's
cheeRS stu
Old Jul 21, 2009 | 07:48 PM
GpA4x4's Avatar
GpA4x4
cheeRS stu
Canna think just now, will measure the morn and txt you
Old Jul 22, 2009 | 08:56 AM
DaveCrack's Avatar
DaveCrack
Whats the price for the injectors mate?
Old Jul 22, 2009 | 12:04 PM
KSA-Cossie's Avatar
KSA-Cossie
engine sold to me will see yot on sunday with the cash
Old Jul 26, 2009 | 05:34 PM
KSA-Cossie's Avatar
KSA-Cossie
Nice to meet you today was a long trip but worth it,there's loads of spares in his attic people so grab a abargain today.
Old Jul 26, 2009 | 07:44 PM
CRAIG HAYTER's Avatar
CRAIG HAYTER
Kev what was wrong with your engine i was under the inttenion you spent alot on it?
Old Jul 26, 2009 | 08:01 PM
STUCOS's Avatar
STUCOS
Nothing wrong with kev,s engine,just this was the cheapest and easiest way for me,to get him more power
cheeRS stu
Old Jul 26, 2009 | 09:20 PM
beemerbazza23's Avatar
beemerbazza23
More power.... Sounds good
Old Jul 27, 2009 | 09:05 PM
KSA-Cossie's Avatar
KSA-Cossie
More power sounds reeeeeeeeeeeeeeeeaaaaalll good.
Old Jul 27, 2009 | 09:14 PM
giga's Avatar
giga
Hi,
Do you have the steering wheel original without air bag to escort cosworth?
Regards
Giga
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
