what heatshield have yous got on your cossies
Old Jul 4, 2009 | 08:19 PM
fordrs2005's Avatar
fordrs2005
Default what heatshield have yous got on your cossies
as above looking for some advise of what heatshields yous are using and whats available for a 3 door
a friend of mine has recently had issues when driving his 3 door on boost the paint on the bonnet is bubbling up above the turbo which is a t34 as hes only running a standard 2wd heatshield
wondering if anybody else has had similar issues as painted the bonnet again but done the exact same again . so now going to go down the route of heat wraping the exhaust and heat deflector on under side of bonnet but just really wanting to see if anybody else had similar problems and what heatshield do they now use to cure this but hes not wanting to go for a 4x4 saff / escort cossie heatshield .
cheers
Old Jul 5, 2009 | 09:45 AM
fordrs2005's Avatar
fordrs2005
anybody ?????
Old Jul 5, 2009 | 10:25 AM
R5FORD's Avatar
R5FORD
www.spec-r.co.uk
got a very good bling heat shield mate.. cover's over the exhaust as well
Old Jul 5, 2009 | 10:37 AM
Captain500rs's Avatar
Captain500rs
Same as that ^^^^ for me
Old Jul 5, 2009 | 04:49 PM
I just got the std 2wd one, cut out for the strut brace, no melted paint on mine(yet).
You can get specific turbo heat wraps so this might be a good idea ?, along with heat wrapping downpipe.
Old Jul 5, 2009 | 04:55 PM
STUCOS's Avatar
STUCOS
Use a standard 2wd one as well ,cut for strut brace,running about 450 bhp and no heat issues with the paint,and gets a hard time
cheeRS stu
Old Jul 5, 2009 | 05:15 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Never seen a bonnet bubble on a cossie from the heat, weird!
maybe the turbo's getting hotter than usual?
Old Jul 5, 2009 | 06:13 PM
Paul_RS's Avatar
Paul_RS
I've a spec R one, anyone fitted a lambda and still retained the heatshield? Its just it looks like its going to be a tight fit!!
Old Jul 5, 2009 | 07:27 PM
col cos1's Avatar
col cos1
ive fitted standard 2wd with strut brace cut
but there is cracks in paint on bonnet above turbo from previous owners ive never sorted out
get the muffler from a 4x4 bonnet and cut that area out
Old Jul 5, 2009 | 07:46 PM
Gav Diamond's Avatar
Gav Diamond
I used some heat reflective stuff from James Listers, had no problems at all with heat from the turbo so far
Old Jul 6, 2009 | 12:00 PM
R5FORD's Avatar
R5FORD
Do a circular cut out in the heathsheild just above the boss for the sensor.. and screw the sensor in over the heatsheild if that makes sense.
Old Jul 6, 2009 | 02:13 PM
space hoppers's Avatar
space hoppers
Originally Posted by R5FORD
www.spec-r.co.uk
he does new design now gives more room at the back and side. call him you will get 10% off fdor being PF member
Old Jul 6, 2009 | 02:18 PM
R5FORD's Avatar
R5FORD
hope iv got the new one
Old Jul 6, 2009 | 02:30 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
You never see the bubbles on my saff bonnet?
Oh hold on that was the fire in the dizzy area that did that
Old Jul 6, 2009 | 02:35 PM
space hoppers
yes mate they have been in production for a year now
Old Jul 6, 2009 | 03:02 PM
R5FORD's Avatar
R5FORD
thats good news then
bobsworth
77
Mar 24, 2016 09:30 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
