XR3i Block?
Old Jul 4, 2009 | 05:22 PM
white2lsr's Avatar
white2lsr
Default XR3i Block?
Could I use an XR3i block to rebuild my rsturbo engine still running MFi? Obviously the turbo oil return would need to be sorted but surely that wouldnt be a problem???
Old Jul 4, 2009 | 05:58 PM
studabear's Avatar
studabear
don't see why not
Old Jul 4, 2009 | 07:01 PM
cabrst's Avatar
cabrst
yes you can, as you say only oil return are diffrent
Old Jul 4, 2009 | 07:18 PM
white2lsr's Avatar
white2lsr
So the MFi head will go on no problem, no issues with oil/water galleries not lining up??
Old Jul 4, 2009 | 09:16 PM
XR2's Avatar
XR2
Heads were all the same and oil and water galleries also. The only differences were - as mentioned - oil return
Old Jul 4, 2009 | 09:18 PM
white2lsr's Avatar
white2lsr
Time to look for a low milage CVH engine to rob of its block. I think it is going to be a good plan as a lot of turbo blocks are needing re-bored these days and I really dont want to go down those lines!
Old Jul 4, 2009 | 09:20 PM
XR2's Avatar
XR2
Piston height of a turbo is different to the XR3i items...
Get new oversized turbo pistons and rebore your block. Believe me, you'll regret it not...
Old Jul 4, 2009 | 09:22 PM
white2lsr's Avatar
white2lsr
hence why ill only be using the block, i have good internals
Old Jul 4, 2009 | 10:55 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
done the same myself once, only oil return needed.
Old Jul 5, 2009 | 03:03 AM
nzwhiteboy's Avatar
nzwhiteboy
where abouts would u put the oil return? ive got a xr3i block here and a RS block but at the moment its a mission to find a RS block in New Zealand and i cant afford to rebuild it just yet so im going to use an xr3i block for a few months
Old Jul 5, 2009 | 04:05 AM
kev new's Avatar
kev new
From: Trailer trash in Oman desert, its good honest Guv!
pretty sure there is a square bit on cast of block that requires drilling and inserting a drain tube prob araldite it in there.....been told its easy to do by an engine builder.
but if anybody remembers the turbo technics rs16I conversion the sumps were modified to take an oil drain instead of doing the block.
gcfcos
59
Oct 6, 2015 05:04 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
