pimping my vauxhall run around....
Old Jul 4, 2009 | 02:48 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
Default pimping my vauxhall run around....
a better use for my alpina rep alloys from my bmw? next on the list is some gsi bumpers , lowered a tad at the front and a new tailgate.
is the principle the same with a turbo diesel, can i shorten the actuator rod a tad for a little bit more power? will a 2wd cossie intercooler make any difference as i have one in my shed ...
Old Jul 4, 2009 | 03:05 PM
paul thornton's Avatar
paul thornton
BMW RS DIESELWORTH
what wheels have you got on the bmw now?
Old Jul 4, 2009 | 03:22 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
The wheels are cool.
Old Jul 4, 2009 | 03:27 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
i was led to believe its a fuel increase you need to go quicker on a diesel but could be wrong.
Old Jul 4, 2009 | 03:29 PM
fuzzy's Avatar
fuzzy
the bmw has vauhall 14" steelies with plastic wheel trims....ill be getting a new set for the bmw soon.
Rossco's Avatar
Rossco
Wheels look cool.
I think its the amount of fuel that limits the power of a diesel.
Old Jul 4, 2009 | 03:36 PM
fuzzy's Avatar
fuzzy
there is a screw with a locking collar on what im told is the fuel pump. i need to give it a turn and a half apparently...
Old Jul 4, 2009 | 03:38 PM
Dangerous Malcolm..
Sleeper look then, nice one.
Old Jul 4, 2009 | 03:40 PM
fuzzy's Avatar
fuzzy
i wonder if the engine will also fit into the van....
Old Jul 4, 2009 | 03:41 PM
Rossco's Avatar
Rossco
That sounds about right. A mate had a Nova TD and he had to weld the overboost valve in the inlet manifold shut once he started getting some boost into it.
Old Jul 4, 2009 | 05:09 PM
coleman's Avatar
coleman
Always in the background
You havent been over to migweb yet then?
There's a guy called RC who's been doing the same model van as you, he's had the 2.0 redtop and the 2.5 v6 engine in his.......
Old Jul 4, 2009 | 06:59 PM
fuzzy's Avatar
fuzzy
ive just shortened the actuator rod about 4mm. im not sure if its the arse dyno effect but it does seem to pull better up to 60/70. i might tyr another few milimetres.
the fuel screw is jambed solid and wont budge, ill try some wd40 over night.
Old Jul 4, 2009 | 09:06 PM
Ginge's Avatar
Ginge
www.virtualseason.net
What Engine is it, is it the izuzu lump?
If so it might be worth a squiz at this..
http://www.migweb.co.uk/forums/engin...ing-guide.html
Ginge
`spotty
Sep 25, 2015 11:41 PM
dombanks
Sep 21, 2015 08:38 PM
tib2220
Sep 14, 2015 12:33 PM
Eigdoog
Sep 13, 2015 05:46 AM
