sold please delete
As above 200 block with 4x4 head, fully rebuilt 600 miles ago can be seen running if your quick, all cometic gaskets including proper copper backed lead bearings none of the cheap stuff, running a yb1261 gasket with ford head bolts, all parts bought from matt lewis motorsport,
looking for £1700ono bare
£2000ono with 2wd ancillaries
Head measures 138.8 and is a rot free 4x4
200 block on standard bore just needed a hone
cleaned and checked pistons with new rings (standard comp)
cometic gaskets except rocker
2wd water pump and stat housing
new seals etc
4x4 oil pump
2wd sump
2wd inlet
4x4 exhaust manifold
YB1261 with standard ford head bolts
matt black rocker cover
engine loom and ecu
crank is std std just needed a polish, copper backed lead bearings
injectors etc can be purchased seperatley, cant think of anything else you may need to know about it, Paul.
new seals etc
4x4 oil pump
2wd sump
2wd inlet
engine loom and ecu
firstable, sorry for my english
we need with 2wd parts, if its possible, with alternator, starter, flywheel and clutch but dont need the loom and the ecu. we using vems, so also no need the ignition.
if you have a gearbox also.
