Ecu
Old Dec 12, 2004 | 04:02 PM
MK5RST's Avatar
MK5RST
Default Ecu
Does anyone know if theres a way to test the BOSCH ecu, Ive tested everything on my RST and theres no spark, everything seems to be as it should, the only thing thats left is the ECU, any ideas?
Old Dec 12, 2004 | 08:56 PM
MK5RST's Avatar
MK5RST
Cmon lads, surely sum1 knows sumthing!!!!!
Old Dec 12, 2004 | 10:38 PM
GrimmeRS2K's Avatar
GrimmeRS2K
buy one they only normally make a tenner on ebay loads about
Old Dec 13, 2004 | 06:56 AM
220TC's Avatar
220TC
how can you test things if theres no spark, that surely means that something is not working
I dont think the bosch jetronic ecu has anything to do with the spark, it controls the fuel !
I bet its your distributor mate, it usually is
Old Dec 13, 2004 | 09:39 PM
MK5RST's Avatar
MK5RST
No, not the jetronic ecu, the ignition ecu,and yes the fuel ecu does have somthing to do with ur ignition as they are both linked, the engine came out of a running erst, ive just bought an ECU from gaybay, ill see if that makes a diference, if not then ill borrow a dizzy from a mate and go from there, ANY SPARE DIZZYS GOING CHEAP?
Old Dec 13, 2004 | 10:36 PM
Paul_RS's Avatar
Paul_RS
I had this exact same problem!!!! i ended up leaving it to an auto spark and they said the fault was in the mutipin plug that goes in the side of the ECU. You should check all the pins are actually connected to the wires in the loom as this was the problem in mine.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
