is the timing different on a kent cam than std
Old Jun 23, 2009 | 07:15 PM
safcdixon's Avatar
safcdixon
SAFCDIXON
Default is the timing different on a kent cam than std
is the timing setting different on a kent cam rather than the std one ive been setting mine to std and it aint working rite not starting properly and ruff on tickover when it does start any ideas would be grateful
Old Jun 24, 2009 | 05:50 PM
project rs's Avatar
project rs
yes the timing is different you need to find what degree the crank should be in relation to full valve lift and follow setting i mentioned in piper topic
Old Jun 24, 2009 | 07:56 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Setting it at TDC like a stock cam is 100% fine, it will not make your car run badly even if it is adrift by a degree or two.
Setting it as project rs says is correct but then you'll go and have the car tuned and your tuner will wang it about anyway to try and squeeze some more horses out!
Adjusting the vernier simply moves the power band up or down the rev range, you can gain a few more BHP but at the cost of low down torque.
jessie_rs
11
Jun 3, 2019 04:57 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
paceo
Aug 27, 2015 12:45 PM
Sultzi
12
Aug 16, 2015 01:08 PM
Zoggon
Aug 10, 2015 10:39 AM
